Timing Issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 07:38 PM
Timing Issue
So I was working on my buddy's 68 chevelle over the weekend, putting on a demon 650 carb and edelbrock intake and comp headers. It is a 350 with cast iron heads port and polished, xe274 cam, and 10:1 compression or right around there. We went to set the timing after setting the carb and when you unplug the vacuum advance the idle changes but the timing does not. When you rev the engine up to set timing, the timing mark goes retarded the more you increase rpm. Shouldn't it advance the more you give it gas? I tried to set the timing by ear and when we drive it, it has a little stumble while cruising, like a misfire, just like the problem I have with my car. Freeway driving is worse, feels like a huge misfire. Any ideas?
Old 08-01-2006, 09:31 PM
batman09's Avatar
CLICK ON MY AVATAR
Did you replug the vacuum port on the carb after you unplugged it?bm
Old 08-01-2006, 09:41 PM
yes, but that has nothing to do with the problem. Thanks Anyways.
Old 08-01-2006, 09:44 PM
batman09's Avatar
CLICK ON MY AVATAR
What I meant is ....did you put a small rubber plug on the vacuum port?If not you basically have a vacuum leak.bm
Old 08-01-2006, 09:52 PM
Sorry, didn't mean to be rude. I now understand what you meant and I thought the exact same thing. I put a plug on the port and after that I checked around for vacuum leaks and found nothing. Thanks again.
Old 08-02-2006, 07:18 AM
Technical Support Barry Grant
What type of ignition system are you using?
Old 08-02-2006, 01:17 PM
nitro_baller4692's Avatar
floppers forever
put a vacumm pump on the vacumm advance an pump it to see if it moves and holds vacumm.
do you have this hooked up to ported or manifold vacumm?
not being a smart a** just trying to help,so don't fell afended for the silly question.
Old 08-02-2006, 06:39 PM
First thing to do is pull the dist. make sure the centrifical advance is not frozen or sticking and the vacuum can is working.
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
Timing issue, I think Sk8Crash69 Engine 10 11-17-2005 11:42 AM
pontiac 350 timing issue Scooby333 Engine 5 01-14-2005 05:55 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
