Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing issues with 1974 sbc 350
  #22 (permalink)
Old 08-08-2010, 05:58 AM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Put the stock weights and center cam plate back on and only use the springs from the advance curve kit if you are using weights that came with a kit. Most kit weights are poorly made compared to factory. Weights don't have to be matched pairs either, you can mix and match different tension springs to further fine tune it.
