timing jumping - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2008, 10:03 PM
timing jumping
i have a 350/330 horse gm crate it was hesitating when i hit the gas when i was timing it i noticed the timing was juming around the distirbutor was tight
Old 04-22-2008, 11:01 PM
Ideas and guesses
1.When was the last time the timing chain and gears were replaced and/or how many miles are on them?
2. Same questions on the distributor.
3. Any chance of a vacuum leak? Old rubber hoses, etc.
Old 04-22-2008, 11:04 PM
Wiki Edits: 31
My dad had that happen on his truck.. HEI modual was bad
Old 04-23-2008, 10:02 PM
racecar100's Avatar
Dial Back Timming Light will sometime show timming jumping around. So try plain jane timming light. Sometime too much Dist Shaft end play will cause timming jumping.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 01:51 AM
timing jumping stinky jinx Engine 3 06-03-2004 12:17 PM
Timing problem - Help MTMike Engine 1 11-13-2002 02:07 PM
