Another thing is if the vacuum advance is hooked up, disconnect it and plug the hose to the carb so you are only seeing initial and mechanical timing w/the timing light. |
also to add, alot of times when guys fix the advance curve so the distributer has no advance at all {fix or lock timing} when you put a light on it, you will still see the timing jump up and down a bit.. thats due to the play or gap between the cam gear and distributer gear with the oil being slushed between the gears.. that play in the gear mesh causes a bit of timing jump up and down.. When you see this kinda timing jump, judge by the highest point on the timing to determine where to set it at even when running engine at 3000 rpm to set totall advance or what ever rpm you choose..
Make sure the distributor is tight sometimes you will think they are but when you rev the engine it will move around enough to through things off and jump around. JMO What type hold down do you have on the distributor anyway ?
Cole
Im going to put in a simpler opinion:
How good is the timing light? And are you using a multi spark system? Some older or cheaper lights dont work at high rpm and many dont work at all with multi spark setups. Typically at higher rpm they jump all over the place simply because the multispark throws them off. Try a better light? |
Cole
You can run the line from the outer ring to the pulley if need be- the pulley is bolted to the inner hub.
I go tthe same damn problem, only mines terrible at idle,
literally jumps about 8 degrees or so Ive been told its the timing chain play..but Im not 100% sure about that |
| timing jumping around | jls4speed | Engine | 17 | 10-06-2010 08:37 AM |
| timing jumping | 88montessss | Engine | 3 | 04-23-2008 09:02 PM |
| Timing jumping | stinky jinx | Engine | 7 | 09-13-2004 02:26 PM |
| timing jumping | stinky jinx | Engine | 3 | 06-03-2004 11:17 AM |
| Trust the timing light or the timing pointer? | lluciano77 | Engine | 6 | 03-06-2004 01:35 AM |
