Timing Light connections
Just asking, is ok to attach red lead on timing light to back of alternator to get power? Any drawbacks? Battery is in trunk. Thanks.
Yes you can hook up at the alternator not a problem, that's not where i hook up at but it will work just fine. but since your battery is in the trunk it's fine. JMO
Cole |
"Any 'hot' source will work. You could even use a battery that is not connected to the engine being tested. (Spare battery or one that is installed in another vehicle.)"
You may have to supply a ground wire to the timing light,from the external battery, if you use an external battery to power the timing light. |
You can even hook up to jumper cables hooked to a battery will work fine. the power source is what you are looking for anyway. as stated though the alt will be just fine .
Cole
| timing light | markzepp820 | Engine | 4 | 09-19-2006 06:15 PM |
| using a timing light | markzepp820 | Engine | 1 | 09-07-2006 08:43 PM |
| how do i use this timing light? | montea | Hotrodding Basics | 11 | 06-20-2004 07:29 AM |
| Trust the timing light or the timing pointer? | lluciano77 | Engine | 6 | 03-06-2004 01:35 AM |
| a little help on a timing light | 75sprintguy | Engine | 5 | 12-04-2003 09:16 PM |
