-   -   Timing light/plug lead Problem (http://www.hotrodders.com/forum/timing-light-plug-lead-problem-232197.html)
dave350v8 04-24-2013 11:20 PM
Hi Everyone,
When I use my snap on dial back timing light, the light does not always flash,
could this be a plug lead fault? Or am I right thinking the "inductive clip" that
I put on the plug lead could be faulty?
I read somewhere that it is suppose to miss every other flash?
Cheers dave
Richiehd 04-25-2013 05:45 AM
Dave, could be wore out. If there is an arrow on the induction clip, make sure it is pointing to the plug. Make sure you have good ground, and move clip away from any other wires, if possible.
dave350v8 04-25-2013 11:53 PM
Cheers mate, will have a look at weekend didnt realise there was an arrow!
If it is worn out can I use another off an old timing light even though its not a snap on?
