Timing light/plug lead Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 11:20 PM
Hi Everyone,
When I use my snap on dial back timing light, the light does not always flash,
could this be a plug lead fault? Or am I right thinking the "inductive clip" that
I put on the plug lead could be faulty?
I read somewhere that it is suppose to miss every other flash?
Cheers dave
Old 04-25-2013, 05:45 AM
Richiehd's Avatar
JS-70
Dave, could be wore out. If there is an arrow on the induction clip, make sure it is pointing to the plug. Make sure you have good ground, and move clip away from any other wires, if possible.
Old 04-25-2013, 11:53 PM
Cheers mate, will have a look at weekend didnt realise there was an arrow!
If it is worn out can I use another off an old timing light even though its not a snap on?
Timing jumping on timing light prettyboyced Engine 13 06-18-2012 10:41 PM
timing without light... markzepp820 Engine 17 03-28-2007 06:11 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
a little help on a timing light 75sprintguy Engine 5 12-04-2003 09:16 PM
No timing light? No problem! BstMech Engine 0 09-15-2002 11:39 AM
