Timing Light Recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 01:32 PM
Anyone got good recommendation for an engine timing light?
What are some things to look for or should be requirements in a light? such as advance dial, amount of degrees etc....
Thanks in Advance
Old 02-14-2008, 01:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Get a good name brand light and yes get one with a advance knob. I have a MAC timing light that I really like.
Old 02-14-2008, 02:38 PM
MI2600's Avatar
Member# 3287
I've got an advance knob Craftsman that gets the job done.
Old 02-14-2008, 04:04 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Summit has good prices on good advance timing lights.
Old 02-14-2008, 04:56 PM
I also have a Mac ... TL 500E ... and I like it.
Old 02-14-2008, 05:04 PM
My 2 cents worth
Wiki Edits: 3
I also have one of Mac Tools Timing lights along with a Snap-on electronic timing light. The electronic timing lights do not work with say MSD Ignition, they just "wig out"(like the old lady). I love my Mac Tools timing light when tuning HP engines.
Old 02-14-2008, 05:09 PM
Holder350's Avatar
Auto Parts Professional
I have a plain old light and wish every time I use it that I had got the one with the advance on it.
I'd love to have a wireless one.....they make them?
mmmmmm got to go google!
Old 02-14-2008, 05:25 PM
My 2 cents worth
Wiki Edits: 3
WIRELESS! I wish multi meters were wireless too.
Old 02-15-2008, 07:57 AM
Here is a good link to consider before buying a timing light as we seen issues with timing lights at higher RPM's with them jumping around.
All the engines we build we degree in the balancers and set the timing at the RPM where the timing is fully adavaced and we run the engine up to 6 or 7000 RPM depnding on the build to make sure the timing stays steady all the way up through and most timing lights are all done over 3500 RPM.
Check this link out.
http://www.chevytalk.org/fusionbb/sh...rch/1/#1298379
Old 02-17-2008, 12:45 AM
I would recommend getting a light with a metal, not plastic, spark plug wire clamp.
I have a nice Sears dial back and I melted 2 induction clamps, due to header heat, as I had to place the pickup down near the spark plug to get a good signal @3000 rpm.
At $45 for a new pickup, I decided to **** can the sears after the second pickup melted.
Old 02-17-2008, 12:54 AM
Put the clamp up by the dist. instead of down by the header and that won't happen.
Old 02-17-2008, 01:15 AM
i have a snap-on, although a little pricey it is the greatest. it has dial-back, reads rock solid at all RPMs, gives a digital readout of degrees advances and also reads RPMs digitally. one great feature is a button that switches the readout digitally from RPMs to degrees advanced and back. it makes it so easy to plot your advance curve. with my snap-on "i don't need no stinken distributor machine"--
Old 02-17-2008, 07:44 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I have a old Sunpro I bought back in the late eighties, it works great. I also bought a Craftmans about 13 or 14 years ago and it is not as good as my old Sunpro. I don't even know if they make Sunpro anymore, if they do I wonder if they are any good.
Old 02-17-2008, 08:28 AM
My 2 cents worth
Wiki Edits: 3
Yep I have one also, but they "wig out" with MSD Ignition.
Old 02-17-2008, 08:29 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
Craftsman is a great deal, and works as well as the higher priced models.
how do i use this timing light? montea Hotrodding Basics 16 08-19-2014 08:03 AM
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
adjustable timing light 55BigBlock Garage - Tools 2 10-27-2007 06:07 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
ignition timing bad502 Engine 21 02-20-2006 06:57 PM
