Timing Light Recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 01:34 PM
Anyone have a good recommendation for a good engine timing light?
What are some things to look for or should be requirements in a light? Such as Advance dial, degrees, etc....
Thanks in Advance
Old 02-14-2008, 01:41 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You already posted this in the Engine forum. It is best not to make duplicate posts. But anyhow...I answered your question over there.
Old 02-14-2008, 02:56 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
sure I got one and would suggest it as a buy. It is self powered and uses batteries for its power. The big advantage of this light is two fold, first you can use it on the side of the road and second one (1) wire to hook up and that one is for the plug. My coupe has the battery located in the rear of the hotrod so the battery thing is real handy . sure I could use the cable on the starter but that is messy dragging the light and wires. It cost around 50 beans ............ advance dial .. mmmmm not sure what that is good for. Get the base timing right and check the full in @ 2 grand (depending on the curve) and you are golden. And if all else fails the thing can be used for a regular flashlight ...... what a DEAL, two tools for the price of one .................. Can it get any better then that ....... waiting.
how do i use this timing light? montea Hotrodding Basics 16 08-19-2014 08:03 AM
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
adjustable timing light 55BigBlock Garage - Tools 2 10-27-2007 06:07 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
ignition timing bad502 Engine 21 02-20-2006 06:57 PM
