timing mark wayyyyy b4 btdc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-01-2010, 07:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Some luck helps, hanging in there is part of the fix too. Here's a picture of a stop I made years ago out of a spark plug. I gutted the inside and epoxied a piece of metal rod into it, making sure it was tight to begin with. You don't want it getting knocked lose inside the cylinder. The contact rod is about and inch long, if I was to use it again I'd make it a little longer. Only turn the motor over until it touches, don't force anything.
Semper Fi
  #17 (permalink)
Old 10-01-2010, 12:59 PM
ericnova72's Avatar
More for Less Racer
I'll just add one thing - when using a piston stop, remove all the sparkplugs, so you aren't fighting against compression and can feel when the piston makes contact with the stop.
  #18 (permalink)
Old 10-01-2010, 02:02 PM
jls4speed's Avatar
thanks guys
engine timing mark ckliever Engine 8 08-15-2010 08:35 PM
installing distributor/timing on sbc 350 075turbo Hotrodding Basics 38 05-19-2010 07:33 AM
Timing / advance eatonde Engine 1 10-08-2008 04:48 AM
Timing mark vs key way on Harmonic Balancer HDPARTSMAN Engine 1 07-20-2006 08:42 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
