Timing marker off 90 Deg? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2008, 04:22 PM
Back info:
I have a small block that has maybe 1000 miles on it since the rebuild. Everything is new, I had been chasing an oil leak for quite a while. I though it was the pan but ended up being the TChain Cover. Since I have replaced that it hasn't really run right. Around the same time I was working on my hood latch that required the removal of the dizzy as well.
What's going on now:
Car runs decent, has good vaccum, around 18 @ idle and it's never iradic. After about 20 min or so on the road, the temp starts to climb and when I park it, the hood is HOT.
What I've tried:
I figure the timing is off so today I re-established my TDC with a dial indicator through the Spark plug hole, and get it set, nothing seems off at this point. So I unhook the vac advance, set my timing light to 0 and start her up. It's pointing almost DEAD on the 90 Deg mark at idle. It didn't do this when I first built the motor but the car has never really been dialed in very well either for lots of various reasons.
SO, is my dizzy off one tooth or what? The car idles fine, but I'm afraid to finish the tune with the timing off this far.
What do you guy's think?
Old 06-14-2008, 04:44 PM
DoubleVision's Avatar
Sounds like a slipped balancer to me.
Old 06-15-2008, 09:14 AM
If the ballancer did slip, could I move the outer ring by hand? I guess i could walk out there and try
I
Old 06-15-2008, 10:41 AM
T-bucket23's Avatar
Wiki Edits: 26
Are you sure you are on #1 plug and not #2. # 2 is 90 degrees off from # 1
Old 06-16-2008, 09:23 AM
You passed!
This was just a test...er, yeah, that's it! Not the best way to start out here but I must have just been tired or something. I know I checked which plug wire I was clipped to but non-the less it was on the #2 plug .
Thanks
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
high initial timing (part 2) stinky jinx Engine 3 08-15-2004 04:54 PM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
