timing on motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2012, 04:56 PM
newbe
timing on motor
is there a difference in the timing on a chevy 350 and a chevy 400 small blocks??????
Old 03-08-2012, 05:04 PM
techinspector1's Avatar
Wiki Edits: 326
There is ignition timing and there is camshaft timing. I assume you're talking about ignition timing. There may have been small differences in ignition timing from the factory, but most all us guys put 10-12 in at the crank with the remainder of centrifugal all in by 2800-3000 rpm's. The combustion chamber shape will make a difference. If you have an large 76cc chamber, it will take longer for the flame front to get from the plug to all areas of the chamber, so you might want to start the fire a little earlier and use a total of 36-38 degrees initial and centrifugal. A later head, like the 64cc fast burn chambers, will want a little less total ignition lead, more like 34 degrees.
Old 03-08-2012, 05:14 PM
newbe
ok im new to building a motor. I got a 400 small block switching it with a 350. it all togther and found out i needed the 168 tooth fly wheel for it and me and my dad wasnt sure if theres a difference in the timing to get it to run correct
Old 03-08-2012, 06:14 PM
Wiki Edits: 326
There are two areas of putting the motor together that seem to draw a great deal of attention on this board.
1. valve adjustment
2. ignition timing
Here's some help for you....
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
Old 03-08-2012, 06:46 PM
Thats a great little tidbit of info.
New motor wont run unless the timing is way advanced z-adamson Engine 18 03-30-2012 04:12 PM
timing help with a built motor v8mazda Engine 6 07-11-2011 07:51 AM
New motor runs rough ,suspect timing - need help Joe 570 Engine 6 04-23-2006 09:42 AM
What should initial timing be on a 94 350 sbc crate motor? batman09 Engine 4 09-14-2004 06:32 PM
Set timing big block blower motor street rodder 1937 Engine 1 10-21-2003 08:57 AM
