I'm not arguing with you but isnt that high for initial timing? I have had the beast running a couple of weeks. It must be pretty damn close...but I have yet to put the timing light on it yet. Going to do it this weekend. It seems to run pretty good. I have noticed a little hesitation at first acceleration...and a little bump..bump..bump while idleing. Will I hear the ping under the hood or out of the exhaust? This thing is damn loud. 3 inch exhaust to 3 inch super 44's dumped at the rear end turned down. Thanks superbeetle.
http://www.youtube.com/user/BigLeoRo.../1/b8qoEh-zh8Y |
You'll need the extra initial cause of the size of the cam you have. You'll be able to hear spark ping from under the hood. I know I could hear mine when I was tuning from under the hood and I just have straight dual exhaust to flowmaster series 40s. You'll have to readjust you distributors advance curve.
My engine has a 234º/234º @ .050 cam and it needed the initial 24-26 timing and 34-36º total. Although, I have mine installed 4º advanced. It doesn't bog what so ever when I mass the gas. That's my understanding. I'm sure someone else will chime in. |
Sounds good. Here's mine running with the timing specs I was telling you about. You'll notice the smooth throttle response as I give the car a little gas to get up the driveway.
http://www.youtube.com/watch?v=wKUldF9XIyk |
From the video it sounds a little choppy at idle. My 383 was similar until I went with 30' at idle (26' seems to be the preferred standard but I've had good results at 30' on mine). It keeps the plugs good, gives you a cleaner higher idle, less gas smelling exhaust, and better throttle response.
Theres a ton of posts regarding timing, but with 26 inital you'd have to limit the mechanical weights You said 22' at 2500?? Youd need 36' at 2500 starting to increase from 1500 I think. For comparison: my 383 stroker is 9.7:1 , 510/512, duration at 50/1000 236/246 |
| Chevy 383 Stroker timing | Hotrodder78 | Engine | 4 | 03-15-2009 11:15 PM |
| Do I need vacuum advance? (Long Post) | Chevy21 | Engine | 49 | 10-25-2007 12:51 PM |
| timing the 383 stroker | 383 stroker | Introduce Yourself | 1 | 12-10-2005 02:29 PM |
| Timing Marks ??? | Zeder | Engine | 6 | 10-08-2003 07:10 AM |
| 92 chevy pickup with 383 (timing & fuel ?s) | dunegoon | Engine | 2 | 12-11-2002 08:12 PM |
