timing on a new 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 01:46 PM
What do you set the timing on a chevy 1996 383 stroker. I have always set it at 0 degrees and the computer took over from there. Now all I get is code 42 est timing error. The motor is set up with a crankshaft sensor which is not being used in my 1995 Suburban. I got a chip from TBI chips to take care of it. It worked well for a few days and then the computer died overnight. New computer and new code 42. Poor idle and performance.
Old 02-01-2011, 04:55 PM
bigdog7373's Avatar
Of course it's fast
Are you using the stock computor with a cam? If so then the cam is causing problems with the computor. Do you have the right distributor? I think its a fuel problem.
Old 02-01-2011, 05:31 PM
I am using the stock computer with a prom chip designed for this engine, it ran great for 4 days then this. The engine is a GM Performance Parts engine for a 1996 or newer engine. That is why I had to use a 1995 distributor and a chip change to run this engine.
Old 02-01-2011, 06:24 PM
bigdog7373's Avatar
Of course it's fast
Hmm. I would double check the timing. You have to unplug some wire though before you set the timing to 0 or else it retards it a lot. Disconnect the wire, set timing to 0, reconnect wire, then start it up and see what happens.
Old 02-01-2011, 06:55 PM
Thats pretty much what I thought, I must have an electrical problem. Just will have to track it down. Thanks for confirming my guess.
Old 02-01-2011, 08:00 PM
bigdog7373's Avatar
Of course it's fast
Do you know what im talking about with the wirenthat needs to be disconnected? A lot of guys on here have had that problem. I wish someone else with more knowlage on the subject would chime in here and give some better info than what i can.
Old 02-02-2011, 07:14 AM
\The brown and black striped wire behind the glove box. Some people refer to it as the pill wire (I don't know why).
Old 02-02-2011, 06:46 PM
bigdog7373's Avatar
Of course it's fast
Yep that sounds like it. Unplug that, set at 0, then plug it back in.
Old 02-02-2011, 07:07 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
The pill wire is where you can tap into to add a few extra goodies if you want to. JMO
Cole
Old 02-03-2011, 07:24 AM
Thanks for the confirmation on the timing. I did all that and the truck wont stay running, I think the chip I bought may be faulty. It ran great for 4 days and suddenly went to hell. I did have a code 51 prom, I put in another new computer and now all I get is code 42 ignition spark timing.
383 stroker timing help? jigga99 Engine 10 08-23-2006 11:40 AM
timing the 383 stroker 383 stroker Introduce Yourself 1 12-10-2005 02:29 PM
stroker timing ???? wheelerex Hotrodders' Lounge 0 05-25-2004 01:30 AM
Timing my 383 stroker vanashae Engine 1 01-12-2003 09:18 AM
Timing a 383 stroker vanashae Engine 2 01-07-2003 03:03 PM
