Timing a non-stock 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 04:15 PM
When timing a chevy 350 that is not stock (aftermarket cam, carb...), what is the best way to determine what your timing should be at? Is it best to set the timing, and then tune the carb, or vice versa? Is there just a set timing, or standard that all small block chevy's work on?
I ask because the engine is running rich, the carb loads up when sitting at the light, and sputters on takeoff (unless I baby it). It also smokes a little when idling. I assume my timing is off, and while the holley 750 is new, it may need to be tuned. Any info is appreciated
Old 05-27-2012, 05:43 PM
Here ya go:
sbc 350, .060 over
speed pro cast flat top pistons
63cc double hump heads (not the 2.02)
edelbrock dual plane intake
Holley 750 vac sec
lunati barebones cam #10001lk
Cam specs:
1500-5,500
Intake Duration at 050 inch Lift 214
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 214 int./224 exh.
Advertised Intake Duration 280
Advertised Exhaust Duration 290
Advertised Duration 280 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.443 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.465 in.
Valve Lift with Factory Rocker Arm Ratio 0.443 int./0.465 exh.
Headers, 2.5" exhaust pipes with flowmaster 40's
Stock gears in the back
Transmission:
TCI streetfighter turbo 350, Jegs 2300-2700 stall conv
I'm also using a hei distributor with an accell super coil, 8.5mm wires and ac delco plugs. I'm not scared to change things, I just really want my engine to be dialed in. I appreciate the help
Old 05-30-2012, 10:08 AM
Thanks for the info, I will use this
Base Timing on stock 305 thunderbritches Engine 3 08-19-2011 04:22 PM
Timing on stock SBC Thors86MonteSS Engine 1 06-23-2011 09:01 PM
Stock 350 Chevy Timing Assistance Please. guysnydr Engine 10 05-27-2010 08:26 AM
Stock 96 Vortec timing 41'srfun Engine 1 05-04-2010 08:53 AM
Timing curve for stock HEI CRT Performance Engine 5 12-01-2006 11:17 AM
