timing off? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 10:44 PM
timing off?
small block 327...750 holley carb...`195s afr heads...msd 6al ignition...i can get the car to start and run at a steady 2000 and up on rpms but trying to bring the car down to a idle to set idle timing car will die...does this sound like a timing issue or something else? any suggestions?
Old 03-08-2012, 08:43 AM
delawarebill's Avatar
idle die'n
vac at the dizzy at idle ??? but my issue is, why do u have a 750cfm on a 327 ???? did u already have it .... but u should be in the 600cfm for normal use.. racing is another issue...
Old 03-08-2012, 10:56 AM
1971BB427's Avatar
Need more specs on the engine. What cam, what compression? Could be your cam is big enough it doesn't want to idle down.
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 02:08 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 08:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
Timing help? Timing bounces and drops?!?! fireforsin Engine 1 09-12-2003 01:32 AM
