-   Introduce Yourself (http://www.hotrodders.com/forum/introduce-yourself/)
-   -   Timing On71 Buick-350-4bbl. (http://www.hotrodders.com/forum/timing-on71-buick-350-4bbl-112158.html)
alrobjr 03-24-2007 07:44 AM
Hello To All Of My Fellow Hotrodders,i Installed A Acell Hei Distributor In A 1971 Buick 350-4bbl.the Engine Clatters On Heavy Acceleration.what Is The Timing An The Correct Way To Time The Engine? Thank You For Aquick Respond Big Al Houston,texas
Henry Highrise 03-24-2007 01:57 PM
Best to ask in the Engine forum.
BuickTim 03-24-2007 02:38 PM
You need a timing light. Disconnect the vacuum hose from the distributor and set the initial timing to 12 degrees advanced. Hook up the vacuum hose and test drive. Buicks like alot of timing, the factory setting is 4 degrees advanced. You should be able to get away with 12 degrees advanced.
Tim
alrobjr 03-25-2007 07:22 AM
timing
thank you very much buick tim,that was right on time.big al houston.texas by the way this buick 350 is installed in a 1981 chevy monte-carlo :thumbup:
