Timing On71 Buick-350-4bbl. - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-24-2007, 07:44 AM
alrobjr's Avatar
Big Al
Hello To All Of My Fellow Hotrodders,i Installed A Acell Hei Distributor In A 1971 Buick 350-4bbl.the Engine Clatters On Heavy Acceleration.what Is The Timing An The Correct Way To Time The Engine? Thank You For Aquick Respond Big Al Houston,texas
Old 03-24-2007, 01:57 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Best to ask in the Engine forum.
Old 03-24-2007, 02:38 PM
You need a timing light. Disconnect the vacuum hose from the distributor and set the initial timing to 12 degrees advanced. Hook up the vacuum hose and test drive. Buicks like alot of timing, the factory setting is 4 degrees advanced. You should be able to get away with 12 degrees advanced.
Tim
Old 03-25-2007, 07:22 AM
alrobjr's Avatar
Big Al
timing
thank you very much buick tim,that was right on time.big al houston.texas by the way this buick 350 is installed in a 1981 chevy monte-carlo
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
pontiac 350 timing issue Scooby333 Engine 5 01-14-2005 05:55 PM
350 sbc timing tigerhapp Introduce Yourself 3 12-13-2004 06:22 PM
350 SBC timing question Magikal Engine 4 02-18-2004 09:55 PM
350 buick buckely53 Engine 3 12-08-2003 07:23 PM
