Timing out because of wrong Damper? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2012, 09:18 PM
I have a '85-'89 stock 350 carbureted small block where I'm having trouble checking the timing. The motor runs smoothly and doesn't stumble, but lacks power (I think). When I set up the timing light I run into this problem. At idle speed, distributor vacuum disconnected I cannot see the timing mark lining up with the pointer. If the vacuum is not disconnected there is no difference. I have an variable timing light and I turn the dial until the mark on the damper comes in line with "0". The timing light now reads 40 degrees. What gives? Do I have the wrong damper on the motor or has it spun enough to make this difference? The timing tab is about the 2 oclock position. And if it is the wrong damper how do I know what the replacement should be?
Old 04-20-2012, 11:40 PM
malc's Avatar
Living At The Speed Of Life
My 86 Camaro´s original 305 had the timing pointer at the twelve o clock position, had to look straight down behind the water pump to see it.
I replaced the damper and unknowingly installed a "two o clock" damper.
Best bet is to get number one piston to TDC, distributor cap off to watch rotor point to number one terminal, and see where your timing mark is damper/timing pointer.
I did that then remarked the "wrong" damper TDC.
Is something horribly wrong with the timing on my SBC? Fenderbaum Engine 9 02-24-2012 09:29 AM
harmonic damper doesn't matich with timing tab? 0pyders Engine 5 03-27-2011 05:18 AM
What am I doing wrong, Timing set sbc 350 aldfaa Engine 3 10-22-2010 09:57 PM
Timing marks on damper redneckhotrods Engine 6 04-16-2010 06:09 PM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
