timing or plugs or carb???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2009, 11:28 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
ok here what happened i took my 76 corvette out it has a 350 with a supercharger on it
i took it out and it was fine parked it and visited a friend for a while then i got back in the car and drove a little it started over heating and then shortly after it started breaking up drove it home and parked in the garage the next day i decided to read the plugs and saw two wet gas smelling plug numbers 7 and 6 at this time the car had autolite 3924 gapped to 45 thous
i wanted to use a colder plug gapped down a little to see if i would benefit
i fixed the overheating problem (electric fans not turning on)
so i changed out the plugs for 3923 gapped to 35 thous and took the car out it was missing like crazy when i go to wot the car misses a lot so i took the car home checked the timing it was about 20 deg at 950 so i took it down to about 14 at 950 and the car does exactly the same thing now here what makes me thing it is the timing with now load i.e. when the car is parked idling and i take it to wot it is fine no miss no backfire its perfect when i drive the car down the block and do exactly the same thing it misses and buck and backfires
i have spent so much time and made so many change on this car i think i am unable to keep up with everything please help me make it right
Old 10-31-2009, 10:50 AM
runn141's Avatar
maybe try a different brand of spark plugs?
new carb/ filed plugs American Muscle Engine 2 09-23-2009 04:56 PM
what RPM to set timing & carb??? yragat Engine 3 08-28-2008 02:34 PM
ignition timing, and carb tuning ? AntiRiceS15 Engine 29 11-02-2007 08:24 AM
Rough Running 355 SBC 355Tbird Engine 12 10-29-2007 01:33 AM
Carb selection help SLR_65 Engine 2 09-03-2007 06:44 PM
