Timing Pointer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 12:26 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Timing Pointer
Does this timing pointer look right to you people? I don't think I can see the timing marks with it.
http://hotrodders.com/journal_photos...1436582212.jpg
Old 03-29-2006, 02:50 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
I can see how you'd be able to see a mark at the hole, but it's gonna be impossible to tell which mark your seeing.
Old 03-29-2006, 03:01 PM
TroyBoy's Avatar
Psychomotors
I see Crazy Larrys point[no pun intended] You may want to buy a different style pointer such as the billet style like they sell at Jegs or Smmit.Just my 2 cents
Old 03-29-2006, 04:32 PM
DHMag's Avatar
not the correct tab for the application but a simple remedy would be scribe a mark at TDC on the outside chamfer of the harmonic balancer.
Old 03-29-2006, 05:12 PM
tornado-tech's Avatar
I did buy a billet pointer from Summit to match the Summit aluminum timing cover. The bolts were not long enough to even go into the block. I talked to the tech department and told them of their problem. I used standard bolts with small spacers to allow 1/2" of thread into the block. Also if you use the billet timing pointer, you have to adjust it to true top dead center as it can be 4 degrees off.
Old 03-29-2006, 05:18 PM
TroyBoy's Avatar
Psychomotors
Answers can sometimes get complicated i.e.I would suggest using a degree wheel to get the timing dead on.
Old 03-30-2006, 08:17 AM
hotrodf1's Avatar
Chasing dreams with a ball bat
Agree with above. Use a piston stop and a degree wheel to make sure your pointer is dead on. Otherwise your frame of reference could be off some. Course, there are way to do this without a degree wheel, but its much harder and less accurate.
Also, I had that same problem, with the pointer sticking out too far. But I just tweaked it a little toward the timing cover. doens't look bad, plus you don't look down there very often anyway. I found it was enough to see my T O C mark on the balancer. I use a dial back light to center the T O C at zero to see where I'm at.
Good luck!
Old 03-30-2006, 09:58 AM
malc's Avatar
Living At The Speed Of Life
This shot is a tad grubby, but it shows the pointer that came with my Edelbrock two piece timing cover.Seems to be shorter than Canadian Charlies
or is his damper deeper, mine´s stock ?
Old 03-16-2008, 01:01 PM
same problem
I have the same problem with my Chevy 350 LT-1. The pointer covers the markings on the damper. I also have an aluminum timing cover which causes the problem, since the rim of the cover is thicker than a stock steel cover, it makes the pointer protrude further out over the damper. Will have to get a different pointer.
Old 03-16-2008, 03:25 PM
techinspector1's Avatar
Wiki Edits: 326
You don't need a degree wheel, here's how.......
http://www.crankshaftcoalition.com/w...ff_for_newbies
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 10:48 AM
Small block chevy timing Anton Engine 1 06-16-2005 10:27 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
Does anyone make an Adjustable Timing Pointer for the Crysler 440? chopper Engine 0 02-22-2004 03:24 AM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
