timing on a pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2004, 12:03 AM
natas's Avatar
timing on a pontiac
how do the marks on the gears have to line up on a 389?
Old 08-07-2004, 03:40 AM
On a 389 set the cam gear at 6 o'clock and the crank gear at 12 o'clock. Then turn the engine to where both gears are at 12 o'clock and set the distributor. Set the distributor to where #1 is pointing towards the area where the throttle cable comes through the firewall. This should get you up and running. Goat
Old 08-09-2004, 01:12 PM
natas's Avatar
thanks for the info it will realy help me out
Old 08-09-2004, 06:38 PM
Your welcome. What kind of Pontiac are you working on anyway? Stock or slightly modified or all out? Goat
