is this a timing problem or carb problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 04:07 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
my 77 nova is acting wierd at very light throttle i was wanting to know if this is possibly the vac advance going out or is it my carb ive set the base at 10 degrees still didnt help then set it to 12 degrees still no progress so set it back to 10 i readjusted the carb still didnt help hopefully someone can help me out i have video of it in the video you will hear my ps pum whining a bit it full on fluid dont understand why it would be whining but my main concern is the engine i will tell ya i do have exhaust leak so i figure id tell you before i post the video the engine runs fine and like i said it only does it at feather light throttle and listen for the tractor like sound in the video
if the video dont show up here it is
http://youtu.be/K2B66uJLfa0
Old 04-24-2012, 06:58 PM
Richiehd's Avatar
JS-70
Tell us more, hard to see what you are talking about. BTW that spring is overextended, you'll be sorry if you leave that like that.
Old 04-25-2012, 01:01 PM
ALL AMERICAN MADE
ok what else do i need to tell its a 350 jasper 11000 on it and the trans like i said it is hard to explain in words what is going on if i give more gas than it doesnt do it, it happens when backing up out the drive way or pulling away from a stop sighn when trying to keep it at a certain speed so what am i dealing with here
Old 04-25-2012, 01:23 PM
Exhaust leak?
Old timey trick was to dribble a little ATF in the carb, and and increase the engine speed and watch for smoke.
Old 04-25-2012, 05:56 PM
ALL AMERICAN MADE
I will try to post another vid when I get home il have my wife hold the brak and il do the brake so I will be under the hood with my phone maybe then yo could hear it clearer
Old 04-25-2012, 06:15 PM
6426yy's Avatar
Have you put a vacuum gage on it and checked that all 8 plugs are firing? Where in Illinois are you?
Old 04-25-2012, 08:59 PM
ALL AMERICAN MADE
i live in lincoln il all 8 are firering but i dont know if at off idle that is when it does it so im not sure if at off idle it is firering all 8 she has tremendous amounts of power tho that im sure of i did do a vac gauge test at the carb on full tim vac port it was reading 17 then go down to 10 and it would just keep fluctuating the whole time at idle
Old 04-26-2012, 04:06 PM
6426yy's Avatar
Your vacuum reading should be steady. you probably have a vacuum leak, throttle shafts sucking air or maybe a burnt valve
Old 04-27-2012, 01:16 AM
ALL AMERICAN MADE
got it figured out the intake gasket was out and also found my fuel leak that i kept smelling and not seeing was comming from the weep hole on the fuel pump and also had a plug wire that was sparking through the jacket but yea got figured out thanks for your in put and this could of been the cause of the vac leak
Old 04-27-2012, 07:20 PM
6426yy's Avatar
Glad to hear! So many guys never get back on here and let everyone know. Enjoy your Nova. I had a 68 wish I still did.
timming problem?? or carb problem???? helppp 85 k5 mud truck Engine 9 06-05-2009 02:29 PM
Holly 4bbl carb help. or timing problem Frequency21 Engine 4 06-05-2009 12:27 AM
Timing/carb problem jdoole3803 Engine 6 08-02-2006 06:01 AM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 12:37 PM
Is this a carb or timing problem? MopaRV Engine 13 12-14-2003 10:21 PM
