-   -   Timing question and cylinder head question.. (http://www.hotrodders.com/forum/timing-question-cylinder-head-question-116529.html)
Blackhauk90 05-21-2007 08:38 PM
Okay so i just rebuilt my dad's motor (1969 302..) Stock everything virtually except cam. It's .456 lift 268 duration so nothing crazy. I was curious whats a good point to just set the timing at? The motor runs as it is now but you can tell the timing's off so i was curious what a good point would be to set it at.. Also.. when i had the heads redone a while ago i asked the guy if he could replace the valve seats with hardened ones and he told me that in 69' they were already hardened and there was no need for a lead attitive.. Was he right or do you still need to add lead if the heads are 69'..?
DoubleVision 05-21-2007 09:22 PM
Chevy or ford? I dunno about fords, but chevrolet didn`t install hardened valve seats until around 73 or so. This was due to lead being removed from gasoline around this time due to strict emissions.
Blackhauk90 05-22-2007 02:10 PM
heh i forgot to even mention.. It's a ford 302..
