Timing question and cylinder head question.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2007, 07:38 PM
Okay so i just rebuilt my dad's motor (1969 302..) Stock everything virtually except cam. It's .456 lift 268 duration so nothing crazy. I was curious whats a good point to just set the timing at? The motor runs as it is now but you can tell the timing's off so i was curious what a good point would be to set it at.. Also.. when i had the heads redone a while ago i asked the guy if he could replace the valve seats with hardened ones and he told me that in 69' they were already hardened and there was no need for a lead attitive.. Was he right or do you still need to add lead if the heads are 69'..?
Old 05-21-2007, 08:22 PM
DoubleVision's Avatar
Chevy or ford? I dunno about fords, but chevrolet didn`t install hardened valve seats until around 73 or so. This was due to lead being removed from gasoline around this time due to strict emissions.
Old 05-22-2007, 01:10 PM
heh i forgot to even mention.. It's a ford 302..
SBC 400 cylinder head question JohnyR17 Engine 9 02-28-2007 04:12 PM
mopar cylinder head question. ramcharger_86 Engine 7 12-17-2006 02:27 PM
BBC cylinder head question Ratoflic Engine 19 11-14-2005 03:22 PM
Cylinder Head Question MrGibbly Engine 1 06-12-2004 05:07 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
