Timing retard - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2005, 10:11 PM
eight90's Avatar
Timing retard
Kind of new at this guys so bare with me. I'm going to lock out my distributor timing, word has it to help the car start easyer you need a timing retard box.I went to the expence of byeing a three step retard box,just in case i deside to run a three step N2O system. Question is, do i have to hook up all the wireing now if all i want is the retard for the initial start up? Thanks in advance.
Old 07-20-2005, 12:15 AM
Siggy_Freud's Avatar
Way too littie information. What type of engine? What type of timing retard box? What do the instructions say? I'd call the manufacturer and ask them or at least get a spare set of installation instructions.
Bringing history and technology together.
Old 07-20-2005, 12:39 AM
eight90's Avatar
350 CID 500HP Small Block Chevy,,,,,,, MSD 8970 retard box,,,, Instructions don't say one way or the other.
Old 07-20-2005, 06:25 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
I am assuming you meant advance...
Unless this is a purpose built Circle track car, I wouldn't reccommend locking the advance on anything. The advance is there to help with spark control as the engine revs up. If you lock the advance out you will have more initial and less total if you try to drive. I saw a car race at the drag strip with a locked advance. Rattled, sputtered and was lucky it didn't destroy the engine.
Also, as a thought, if a locked out advance worked that easily, everybody would have done it. Although following someone else guarantees you secon place. If you want try it, go for it, but I don't think you wil be happy with the results.
Old 07-20-2005, 11:20 PM
You shouldn't have to hook up all the wiring if you just want the first stage retard for startup. It should have a diagram listing what wires need to be activated (via 12v or ground depending on the box) to initiate its cooresponding stage of retard. Just hook up the first stage and tie off the other ends and you should be good to go. You'll want to hook up the trigger wire to a cranking 12v's. Meaning you only want that retard activated when the engine is cranking. Splice off the power feed that feeds the small terminal on the starter solenoid.
I have used Crane's box with its single stage retard for Nitrous. We used a dial located in the car to determine the amount of retard we want.
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 11:48 AM
ignition timing bad502 Engine 21 02-20-2006 07:57 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 08:52 PM
BBC Timing Top Rod Engine 0 06-09-2002 09:29 AM
