Timing Roots Blown SBC - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-03-2013, 10:09 AM
blowme77's Avatar
Aussie Redneck
Yeah, currently running a msd digital 6 plus, with billett 85551 dizzy. Looking into buying a BTM to suit.
Seems like the best way to get the start retard and boost retard.
  #17 (permalink)
Old 06-03-2013, 10:30 AM
NOlowrider's Avatar
US Navy-Retired
If you are running high SCR, high boost, pump gas (like you are) def get the BTM. It's not hard to install, especially with the MSD dist. Lock out the timing, IMO
  #18 (permalink)
Old 06-05-2013, 09:21 PM
471A
listen to F Bird
Until I found F Bird, I was having constant back fire problems with a 4:71 dual quad combination atop a 355 SBC. Advice: listen to F Bird !
  #19 (permalink)
Old 07-08-2013, 01:25 AM
blowme77's Avatar
Aussie Redneck
Just a bit of feedback here...
I went ahead and built this engine combo despite the warnings....
350 block 2-bolt mains, bored .060, scat stroker kit (all cast), 388ci, cast I rods, 18cc dished hyper pistons, edelbrock e-street alloy heads 64cc, comp cam hydraulic NX274h 230/244 duration @ .05, MP122 roots blower (running 5lbs boost), 800cfm eddie carb, Msd Digital 6plus ignition & billett dizzy, timing 22* initial & 32* all in, Msd BTM taking out 1* per lb boost, 2500 stall, 3.55:1 rear gears.
The 9.7:1cr & 5lbs boost on 93 PUMP gas Rocks!!! No signs of detonation, Great street manners (once it is warmed up), Great bottom end torque (thanks to the blower), Pulls hard right up to 6000rpm easy!! Biggest problem I got now is getting my 295 street radials to stick to the road!! Cant wait to take it to the track!
Very happy :-) :-) :-)
  #20 (permalink)
Old 07-08-2013, 06:47 AM
vinniekq2's Avatar
new engine
Originally Posted by 68NovaSS View Post
I run an 8.4:1, 8-71 383 on the street with a BTM and injection system. The one time I sent my BTM to El Paso for repair, bought a 6AL for the weekend test and tune, before the inj system, with fixed timing at 34*, I melted 7 pistons, an expensive lesson, I couldn't hear it detonating, but sure felt it lay down on the third run at 1,000 feet.
enjoy the engine?sounds like it should make 500 hp
  #21 (permalink)
Old 07-08-2013, 08:38 AM
I agree with fbird88.....get those pistons outta there. The first time you get over zealous with the throttle, push alittle boost, go a little lean, get some not so good gas and greedy with timing (one or all in combo) the engine will collapse the ring lands on the pistons, stick a coupla rings and that'll be the end of that. Ask one of my friends that just had to have a 6-71 on his 454 with 10.25-1 despite me telling him many times "hey, ya got it down, put some other pistons in there" Oh no they'll be fine, I'll run light boost, he says. Ok my friend, knock your self out. He listen's to me now!! He understands experience now.
  #22 (permalink)
Old 07-08-2013, 10:33 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Enjoy the engine? Heck yeah, lol. I suspect more than 500 with good gas, never been on a dyno. I do have two custom grind Lunati solid rollers, distinctively different characteristics, that's to be expected.
Semper Fi
blown 400 sbc timing? nastysmallblock Engine 11 05-18-2011 10:29 PM
Help-how to overdrive a roots blown engine? drgnII Engine 2 03-02-2010 01:02 PM
All Roots Blown Cars Here Please!!!! AFBCamaro Engine 5 06-21-2009 07:53 AM
Proper Timing For A Blown Sbc hotstang3 Engine 7 07-11-2005 07:51 PM
