Timing on a sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 11:10 PM
Timing on a sbc
Okay so I have a sbc 355 with a cam. I bought a distributor and was wanting to know if I find number 1 with tdc. Can I put a socket on the crankshaft pulley and move it to 12 before top fead center that way I dont have to make up for the amount I would have to turn distributor or does the timing tab have to be at 0.
Old 08-18-2012, 11:15 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You can try to put it on 12 degrees, but chances you'll get the tower on the distributor exactly on #1 is a crap shoot. Just get it close, start it and time it.
I wouldn't use a socket on the crank bolt to turn an assembled motor.
Semper Fi
Old 08-18-2012, 11:18 PM
Will I know it wont be exact but thts not what I said. It will be close and tht way I dont have to turn distributor as much ratger than if hamonic balancer was right at zero
Old 08-18-2012, 11:50 PM
Timing on a sbc
Yes you are correct. With a helper bump the engine over until air is being forced out around your finger. Then turn the crank by hand to 12* BTDC. You can check by pulling the distributor cap to see if the rotor is pointing to #1 or is close. Replace the cap and start the engine to set timing.
Old 08-18-2012, 11:55 PM
So the rotor will be pointing at number 1 at roughly 12 btdc ?
Some people do it at 0. What would be tge diffetence
Old 08-19-2012, 12:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hardly any difference, nobody gets it right on, and 12 degrees doesn't take hardly any distributor movement. Start anywhere you like, just get it running and time it to where you want it, if you have vacuum advance, disconnect and plug at the source.
Semper Fi
what timing for sbc old fords Engine 5 10-04-2009 06:42 PM
sbc timing with no timing tag excaliberprime Engine 5 04-14-2007 10:58 PM
SBC Timing dwc12345 Engine 12 06-26-2006 08:00 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
best timing for a sbc billybob_v10 Engine 1 08-26-2003 12:45 AM
