timing set replacement on 454 bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 04:25 PM
so i recently chenged the timing set on my 454 to a double roller set. the old cam gear was so worn that it had jumped time. when i insatlled the cam gear i could only get it to go on to the cam with the timing dot in the 12 o'clock position due to the position of the a;ignment dowel on the cam. and i know that its supposed to be in the 6 o'clock posion in order to line up with the mark on the crank gear which is at the 12 o'clock position. i was just wondering if this means that my cam was 180 degrees off because i had cranked the engine with #one plug out till i heard compression then turned it to zero with a wrench. but when i took off the timing cover the timing marks were in the right positions but since it jumped the cam was a tooth or so off. so i dont really understand why i couldnt put the new cam gear on in the 6 o'clock position instead of the 12 o'clock. any suggestions are appreciated thanks for reading
Old 08-04-2010, 05:52 PM
BOBCRMAN@aol.com's Avatar
Cam turns 1/2 engine speed. Cam can be installed at 12 or 6 as long as the timing dots are in a straight line with crank dot. it doesn't matter.
Old 08-04-2010, 10:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The only reason the cam gear is installed w/the timing dot @ 6 o'clock and the crank gear @ 12 o'clock is simply a matter of being able to easily tell that the marks are in alignment.
If you installed the cam gear dot @ 12 o'clock w/the crank gear dot also at 12 o'clock- as long as the dots were in exact alignment- there is nothing wrong if when you turn the crank another 360ļ that the dots align.
It is much easier to use the cam gear for reference and turn the camshaft until the cam gear dot is at 6 o'clock before installing the timing set, and if this ever comes up again I'd suggest you do it this way- it is a LOT easier to tell if it's in alignment that way.
Old 08-05-2010, 12:53 AM
thanks guys thats what id thought cause the engine runs normally. i just wasnt sure if i did something wrong but i was vrry careful to take a straight edge to find out if everything was properly aligned. i appreciate the help
First BBC, urgent help with timing! Forza1 Engine 18 08-05-2010 08:38 PM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 09:40 AM
How to correctly set timing and advance? Cousin_Joe Hotrodding Basics 2 02-28-2008 06:31 PM
HELP! New timing set too loose dran04u Engine 1 06-26-2003 05:14 PM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 05:26 PM
