Timing setting for 1976 350 marine engine
I have been rebuilding a 1976 350 GM marine engine, I did away with the points and installed the electronic spark system, this ignition does not have a vacuum advance nor did the prior system. so I just wondering what degrees the timing should be set at.
As a Moderator ,
I am going to move this thread to the engine area of this board where hopefully it will be viewed by more members with engine tuning experience. Deuce
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Most SBC engines w/OEM heads from that era use around 36 degrees of total timing. You want to set the springs to bring the mechanical advance in starting as early as you can w/o any detonation, and all in by 2800- 3000 RPM. This varies by weight, hull, prop, etc.. Keep a close eye on the plugs if you get out to the max timing- they are your "window" into the combustion chamber. They should have some color (a light to medium tan used to be what was looked for), but w/the unleaded swill that's available now- often diluted w/alky- the color is harder than ever to read correctly. But you want some color, be it tan, gray or whatever- and not stay white. |
timing
that sounds like good advice I will definitely try that.
| Low buck 355 sbc not running correctly, wanting to much timing. | ForceFed86 | Engine | 68 | 04-13-2011 12:35 PM |
| Engine Timing Problems | fiftyfivegasser | Engine | 6 | 04-20-2010 05:59 AM |
| running no vacuum advance | oregon chevelle | Engine | 30 | 02-07-2007 07:17 PM |
| No ported vaccum port in my Q-jet, help | Augusto | Engine | 11 | 12-27-2006 05:04 PM |
| Timing Specs for chevy 350 engine | 68_Convertible | Engine | 3 | 11-25-2002 05:51 PM |
