timing small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2007, 10:54 AM
I have a 283 cu in with 305 heads and a 305 Harmonic Balancer. A Machine shop rebuilt it. They realized that the balancer's Timing Mark is in the wrong location for a 283 and therefore they set the engine #1 Top Dead Center compression and marked the balancer. Now for some more complications: .it has a Gear Drive in it and I do not know if they used a retard or advance key (?) nor do I know what kind of cam it has in it. When I try to set the Timing with a light I have to retard it a lot to even see the mark.....have to bump up the idle to keep it running. So that doesn't sound right. I have had the distributor in various positions and it doesn't seem to affect the performance of it. any recommendations?
Old 09-24-2007, 11:18 AM
nitro_baller4692's Avatar
floppers forever
talk to the shop who put it together and if they don't help you i would never send anything there again.
Old 10-07-2007, 01:50 PM
Berliner Bel Air's Avatar
Beyond the Sea
Set the timing mark yourself with a positive stop thingy in the number one cylinder. Not hard, then you'll know for sure. I also had to do this for my 283 for the same reason.
The stop should include instructions on how to use it.
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 06:33 PM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 04:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
Timing for a chevy 1968 307 small block 61ChevyTruck Hotrodding Basics 2 03-02-2004 06:45 AM
