Timing steps please - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 09:32 AM
scapegoat's Avatar
Timing steps please
I know this has probably been beaten to death but I just got my sbc 355 running again thanks to you guys. I know it should be timed at 36 degrees. What are the steps to achieve this? It has a hei with vacuum advanced which I don't really care to use. What is total timing and initial? Thanks fellas.
Old 04-07-2008, 11:02 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
This link may help you, scroll down the page about halfway, ignition timing your hot rod.
good luck,
Rich
http://www.gnetworks.com/v4/go.gnf?s...1_i2_w1_f1_001
Old 04-07-2008, 12:48 PM
scapegoat's Avatar
Originally Posted by richard stewart 3rd
Hi,
good luck,
Rich
Wow. Lots to read but still confused. How do I know the difference between total and initial? Do I time it to 14ish degrees and then rev it up a little and watch how much it advances mechanically,then add the two to get my total?
Old 04-07-2008, 01:10 PM
speedydude's Avatar
Registered Cruiser
Remove the vacuum advance hose and cap off where it was connected.
Make sure the idle is around 700ish rpm.
Set initial timing from here. Say 10-12* to start.
As you increase engine speed make sure the mechanical weights in the distributor are advancing the spark. This should add around 20-24*
After all that's done hook up the vac can and check operation of that as well.
Any clearer????
Old 04-07-2008, 01:29 PM
NOlowrider's Avatar
US Navy-Retired
If you are not going to use the vacuum advance, plug it off and just turn the dist. until you have 36* at 3,000 rpm. This will let the initial fall wherever it wants to. In other words just set the total and the initial will take care of itself. You may have to play around with the total a bit, give or take a few degrees to keep her from detonating.
Old 04-07-2008, 02:16 PM
Hi,
This is a long thread, but worth reading.
Rich
http://www.jalopyjournal.com/forum/a...hp/t-7609.html
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 01:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
Timing problem - Help MTMike Engine 1 11-13-2002 02:07 PM
