timing tab missing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2007, 09:28 AM
timing tab missing
I have a 350 olds motor and went to time it and it doesn't have the degree tab , anyone know if they make a universal one ,my parts distributor has one for a chevy motor . will that work .
thanx
jim
Old 07-26-2007, 11:18 AM
speedydude's Avatar
Registered Cruiser
The Chevy one may or may not work, manufacturer's did different things at different years. Could be possible. You'll need to establish exact TDC. Go to the knowledge base for this, there's also been alot of posts on ways to establish this. I personally liked Doc's method. Then you'll need to fasten the tab to the block day~um close.
I have a diagram for olds 350 timing tab but what year is it??? Is this engine out of the vehicle???
Old 07-26-2007, 01:16 PM
techinspector1's Avatar
Wiki Edits: 326
Chevy motors have 3 different combinations, I don't know about Olds. I think I'd get a top dead center piston stop and a degree tape and establish TDC before I trusted just any old timing tab.
Old 07-26-2007, 01:23 PM
its a 1972 motor and is in the car , picture would be helpful.
thanx speedydude
Old 07-26-2007, 02:04 PM
speedydude's Avatar
Registered Cruiser
As mentioned in the post by the Spector, TDC piston stop and degree tape to me is critical. I'm going to assume here that you will want to dial in your timing for your specific application later, not just turn the dizzy until the engine quits pinging!!
If you have a fax #, PM me and I'll get the diagram I have to you. If not, maybe I can scan it..............maybe
Old 07-26-2007, 02:49 PM
thanx
jim
The Olds timing tab is completely different from the Chevy tab. Olds used two different types. The 1960s and 70s motors have a stamped steel tab, the 1980s motors used a plastic one. I don't know if they interchange or not, but I'm willing to bet they do. The tab is retained with the two bottom driver's side bolts on the front cover. The tab from any Olds V8 (455, 330, 400, etc) will work.
Old 07-26-2007, 03:36 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
I have a 1977 olds Cutlass that has a 350 rocket motor or what most people I know call it a 355? anyways I set the timing the way I was taught on a 350 chevy. Bring the #1 piston up to top dead center. Mark the dizzy to the post on the dizzy cap for the #1 plug then put the wires in this order 18436572 it should run fine.. Mine does maybe I got lucky
hope this helps
Ed
Old 07-26-2007, 03:43 PM
speedydude's Avatar
Registered Cruiser
You are exactly correct Joe. Olds 350, 400, & 455 all the same. This tab also looks identical to my '71 Chev 350 tab. Don't know if it's exact but looks awfully close.. Interchangeable???
Maybe get the Chevy one from the parts house and compare it next to one in a wrecking yard??
Old 07-27-2007, 09:12 AM
Again, the Chevy tab will not work. The Olds tab picks up the two lower timing cover bolts on the drivers side as well as the dowel pin. Chevy motors are different in this area.
Old 07-27-2007, 02:20 PM
thanx for the advice looks like a junk yard part, live in the detroit area should be easy to find.
Old 07-27-2007, 02:59 PM
Holder350's Avatar
Auto Parts Professional
I was thinking that I bought a chrome tab that bolted with the timeing cover bolts to the block and it had a third hole for the alignment pin.....its on a motor at the house. I'll check tonight and get back to you.
Also make sure that someone hasnt put a aftermarket balancer on it measure it around the outside of the balancer.....its concevable that it had a 6.5" on it and someone put a 7" in place of it...and cut the tab off
Old 07-27-2007, 03:09 PM
That's all good advice, but trust me, you just CAN'T buy that stuff for an Olds motor. You Chevy people are spoiled...
Old 07-27-2007, 03:49 PM
Holder350's Avatar
lol I guess so....never delt with Olds stuff.
I like that fact that everyone on the planet has reprduction stuff for the old SBC
Old 07-27-2007, 04:32 PM
Holder350's Avatar
I guess its true.....you can find anything on ebay. Is this what your looking for?
http://cgi.ebay.com/ebaymotors/1968-...spagenameZWDVW
Old 07-27-2007, 05:14 PM
Last journal entry: frame build
thanx
jim
Universal timing tab= short piece of stainless steel wire , available at your hardware store. Put a loop in one end, bend to fit your timing mark 0 at top dead center. Bolt to timing cover and your good t go and it don't cost squat.
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 10:48 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 08:56 PM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 12:51 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
SBC Timing indexing a unmarked 4.25 blower hub and custom tab 614streets Engine 9 06-14-2003 04:26 PM
