Yea, there are different timing cover/balancer combinations. If yours is up top, it is kinda tricky looking straight down behind the water pump but can be done, providing you have the correct pump on the engine.
Mark |
Actually, the "up top" tab is not that bad given the tight quarters and the P/S pump. The stock version of that tab had a tube thingy on it too that was used for a sensor on the older scopes to read timing on the scope without using a light. Pretty cool "back in the day"! LOL
Which water pump is on it? Long or shorty. Sounds like the short, older style pump is on it now. You may have to switch to the smaller balancer and timing cover or just add the bolt on tab with the smaller balancer.
Chevys used a 12:00 O'Clock, a 2:00 O'clock and a 2:30 O'Clock timing position. You can change your timing position using a 2:00 or 2:30 tab and a timing tape on your damper. Follow this procedure, except with the heads off, use a piece of strap steel (1/4" X 1" works well) which bolts across the cylinder bore and has a bolt threaded through it to act as a piston stop.....
http://www.crankshaftcoalition.com/w...ff_for_newbies Scroll a little more than halfway down this page to "Positive Stop Method of finding T.D.C." to see the strap and bolt..... http://www.iskycams.com/camshaft.php |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| timing tab missing | jimdzendzel | Engine | 18 | 07-29-2007 07:12 PM |
| ignition timing | bad502 | Engine | 21 | 02-20-2006 06:57 PM |
| Timing on a sb350 | jrm123180 | Engine | 4 | 10-14-2004 08:36 AM |
| IGNITION and CAM TIMING | sum87mustang | Engine | 3 | 07-11-2003 07:52 PM |
