Timing tabs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 04:05 PM
Oregonite's Avatar
Timing tabs
I have an 8" balancer on my 327 and the timing mark is at the 12:00 position when I try to time it. Does Mr. Gasket or Trans-dapt sell one that will bolt up to the Gen 1 sbc. or will I have to remark my balancer so I can use the 2:00 position timing tab that I have now?
Old 04-07-2013, 04:44 PM
poncho62's Avatar
Wiki Edits: 5
Remark the balancer. Make sure you check for TDC to get it just right.
Old 04-08-2013, 02:10 AM
techinspector1's Avatar
Wiki Edits: 326
Here's how to do it....
http://www.crankshaftcoalition.com/w...op_dead_center
Old 04-08-2013, 08:56 AM
I have a Summit #163625 pointer and a Pioneer 872021 damper. The damper is marked 50 deg. BTDC - 10 deg. ATDC . The maximum damper diameter for the pointer is 6.250" OD and the damper is 6.100" OD. Works very good, if I use it. My engine is timed by the ECM and a 1992 R.P.O. 9C1 Police Pursuit ICM which bumps the total advance 4 to 6 degrees between 3000 and 4000 RPM, compared to a regular production emissions ICM.
What's the deal with different timing tabs? Silver Surfer Hotrodding Basics 3 07-30-2011 03:50 PM
timing tabs jbwarren Hotrodders' Lounge 0 12-25-2008 11:04 PM
SB Chevy Timing cover w/2 tabs? L72Belair Engine 2 03-05-2006 08:57 AM
Help with tabs on MSwindows XP ChevelleSS_LS6 Hotrodders' Lounge 5 05-05-2005 09:15 PM
Timing tabs WakBordr7387 Engine 5 03-22-2005 03:37 PM
