Timing tape came off? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 05:45 PM
I have a BDS balancer and it does not have the timing marks in the balancer so I had to use the tape, well I guess I must not have cleaned the balancer before I put it on and now it came off. So my question is, is there any accurate way of getting TDC with out using my degree wheel?
Old 02-14-2008, 05:52 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
You could try putting something in the spark plug hole to stop the piston before tdc and make a mark, then turn it backwards till the piston stops and make a mark, then just split the marks. It's not as accurate as with the head off and a degree wheel, but might get you close enough.
Old 02-14-2008, 06:36 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...ff_for_newbies
window install Jzarczyn Body - Exterior 10 01-25-2009 12:02 AM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
"Basics of Basics" Reverse masking for two tones MARTINSR Body - Exterior 0 03-13-2007 12:32 AM
Basic of Basics - Windshield Installation Kits firebird_red Body - Exterior 15 11-26-2005 10:00 PM
Installing back glass on 66 gto.. help beemdubya Body - Exterior 4 10-12-2005 11:32 PM
