Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing and TDC problem
Old 01-10-2013, 02:16 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by 1932bantam View Post
he said he made a new mark with the new pointer installed that should work.
Correct. Assuming that you disconnected the vacuum advance line and plugged it, you should be reading the correct initial/centrifugal timing. Borrow a plain old, NON-FOSDICK timing light from one of your buddies and have another look.
