Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing and TDC problem
Old 01-11-2013, 05:51 AM
cdminter59 cdminter59 is offline
Why would you want to know this? Can you see the scale and the original mark on the balancer? I am assuming you are using the new mark and the timimg pointer you installed. But if you have the new mark on the balancer lined up with the pointer. Look for the largest V cut in the factory scale. The original line on the balancer should be close to this.
