Timing Timing Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2009, 06:46 PM
Trying to figure out all the different aspects of distributor timing.
What is intial timing, and how do you figure it out if you doint know it (89 model 302 by the way). Also, how would you adjust it?? Is that the timing that is set generally with a timing light at idle, with the vaccum advance disconnected? With no advance involved I assume that is the "initial" timing.
What about the centrifugal advance inside the dizzy, the weights and springs. Why would you adjust that? When does it come in? Too fast or to slow, and how would you figure it out.
And the Vaccum advance, can that come in too fast/slow? How do I adjust that?
And what is the reason for a lock up dizzy?
Oh, any good reading material on this subject?
Old 01-19-2009, 10:29 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
here's a link to 200 threads that have to do with ignition timing.....
http://www.hotrodders.com/forum/sear...archid=2304868
Old 01-20-2009, 08:14 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
http://www.hotrodders.com/forum/sear...archid=2303863
good information just does not work ................... the link
Old 01-20-2009, 10:04 AM
Senior Curmudgeon
Wiki Edits: 326
Changed and hopefully fixed....
Old 01-20-2009, 10:20 AM
tech,,,LOL,,,I moved the BG site timing article to a desktop shortcut since I post it so often as a link!!!
big country,,,here' ya go
http://www.gnetworks.com/v4files/bar...withimages.pdf
without further car and motor details that's all I can do to help...
Chevy or Ford 302?
here's a AMC/AMX motor article from the "Knowledge Base' link at the top of this page that may help....
http://www.amxfiles.com/resource/tech/timing.html
Old 01-20-2009, 05:22 PM
Okie dokie, thanks fellas, I'll do some detailed reading tonight. My vehicle is an '84 Ford F-150 with an 89 302 that I put an intake and carb on. I wasn't so much searching for specifics for my truck, but general info and procedures.
Old 01-20-2009, 05:47 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Here's a good simple look @ ignition systems
http://auto.howstuffworks.com/ignition-system.htm
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
