Timing tips - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2010, 08:48 PM
Timing tips
11 to 1 383 292hyd cam msd probillet dist an 6al im running 12degree initial an 36 total all in at 3000 rpm, im not using my vac advance cause my predator carb hasnt a vac port for it, would it benefit me to use a vac advance? i just play at the track with it where it never sees low rpms anyway
Old 08-13-2010, 09:10 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I wouldn't bother with vacuum advance on something like what you're using that for anyway,
Old 08-13-2010, 09:14 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
That looks good and I do not think vac advance would be any benefit, might want to play with the springs on the curve, and have that 36 degrees all in at 2500, the lightest ones will do it, MSD curve kit a nice handy little item comes with 3 sets of springs, one throw away set and the other two you can mix and match, The kit also has the stop bushing for the counter weights.. here is the kit # if you have not seen it before.
http://www.summitracing.com/parts/MSD-8464/
.....predator ......... nice love the name like the carb.. .
Old 08-14-2010, 10:09 AM
When you say "it never sees any any low rpms" do you mean you have a standard shift. or a trans brake automatic. or leave in the stall of the converter. 12* initial is low if you are stomping on it from an idle. You have 24* mechanical, thats alot. Use the black bushing which is 18* mechanical advance and get that initial timing up with an automatic.
Old 08-15-2010, 02:32 PM
1958 Olds 371
I have a 1958 Olds with a 371 2 barrel. When I got it it had a dead cylinder, low on oil, and vacuum problems. I fixed most of that, but it still wants to struggle when sitting still and in gear. In park or neutral, it almost feels and sounds normal, but the extra load makes it shake when you put it in drive. When I fixed the dead cylinder (plug wire), I thought it might shape up. It obviously helped a lot, but I am still looking for more. I am not a mechanic, and I'm finding it hard to find too many guys in my area that are interested in doing much looking at it. I actually had a couple of locals do a little tweaking, and neither found the plug wire, so as I said, I don't think their "hearts" were in it.
My question is, I was reading an older post on here about timing, vacuum advance, ported vacuum, and manifold vacuum. The guy that had this before me did some jerry-rigging on a lot of stuff, and the current set-up uses ported vacuum. However, I discovered yesterday that the old vacuum advance can is bad anyway, and have ordered a replacement. I would like some more expert opinions on the subject of getting this correct. I plan on trying to set the timing again, vacuum advance disconnected, and then reconnecting it to the best source. Some of the guys said that manifold vacuum really gave them a boost, but I would like to hear some more about it. I realize there could be more issues, such as compression, rings, valve issues etc., but I would like to at least give it the benefit of the doubt and do what I can first to see if I could get it to be a daily driver.
Thanks to anyone who might have an idea or two.
Old 08-15-2010, 07:30 PM
Ya its a manual trans thanks for the replies
Old 08-24-2010, 08:24 PM
kficiur's Avatar
Originally Posted by F-BIRD'88
With the big 292H cam try locked out timing. The low rpm throttle response and idle quality and spark plug life will be much better.
The big 292 magnum needs a lot of timing at idle. Much more than 12deg.
Short limited 10deg mech adv curve ....26 initial at idle 36 at full advance or just lock it out.
F-BIRD'88, I'm running the same cam in my nova. I drive the car on the street and I need it to start decent when hot. I'm going to try the 26/36 tomorrow, right now I'm using the 18 degree bushing and it isn't quite right. Locked timing might be the way to go huh? Could I just use a MSD retard box for start up? I'm going to be using one anyway. Thanks for the info.
Old 08-24-2010, 08:50 PM
bubbahotep's Avatar
Ive a similar setup and used F-Birds advice in the past. I have an MSD retard box that works great. I had issues of hard starts even with the retard which turned out to be an out of phase rotor why I corrected by adjusting the vac advance arm. After that the retard works great even when hot
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
Timing / advance eatonde Engine 1 10-08-2008 04:48 AM
ignition timing bad502 Engine 21 02-20-2006 06:57 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
