timing trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2002, 06:15 AM
CARGUY's Avatar
Post timing trouble
im working on my friends 68 el camino with 350 the problem is when you try to get the timing anywhere close to the timing tag it dies it will run if you jack the timing up we pulled #1 and started over and it was right but it still wont run <img src="confused.gif" border="0">
Old 07-21-2002, 07:41 AM
hotrodit's Avatar
Thumbs up
Hi, take look at page two under timing problems it may help! hope it does.
Old 07-21-2002, 01:11 PM
Post
It sounds to me that the front vibration dampener has spun in the rubber. In other words you need a NEW FRONT Dampener.
Old 07-22-2002, 05:26 PM
54 Chevy's Avatar
Post
Man, I know how you feel. I have the same problem on my 1967 327ci sbc. Please post if you solve this problem. I even checked to see if my balancer went twisty on me and mine was fine. I put the engine at TDC and checked the timing tab matched the mark.
Sorry I dont have anything to offer but company for your misery.
Jim
Old 07-22-2002, 06:08 PM
Post
make shure you have correct timing tab on engine .try this ,bring #1 cyl up to timing mark TDC and then take off plug wire to #1 put in a spark plug and ground it rotate dist clockwise as far as possible .turn key on and turn dist counter clockwise till you see it fire snug dist then start engine let warm up shut off engine and turn dist a little at a time till kicks back against starter and back off 1/8 to 1/4 inch .engine will run great regardless what marks show .have done that to a few chebbies that i couldnt get marks to work and used it in oval track race cars also good luck
Old 07-22-2002, 06:15 PM
CARGUY's Avatar
Post
thanks for all the help we put in a new distributor and carb and that seems to have solved the problem
[ July 23, 2002: Message edited by: CARGUY ]</p>
Old 07-22-2002, 06:20 PM
mr_chickenhead's Avatar
Post
I had a simular problem once after I changed my stock 2brl intake with a 4bl. Could not time it any where even close. Still Ran though. Ended taking it back off 3 weeks later to put it on another car and put the stock intake back on, got timing to go back to 8. Figured the carb might have been funny?
Old 07-22-2002, 06:21 PM
Post
