Timing Trouble 350 TBI - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2004, 09:27 PM
New Member
Today I started my new adquisition 350TBI, but this has problem with timing ignition, beetwen idle at 3000 RPM no change timing , It follow in 0 degree and after 3000RPM aprox Up.
Also in idle the RPM UP and down, is not smooth. I out IAC but the problem follow.
Help please
Thanks
Old 12-11-2004, 09:55 PM
Did you unplug the SPOUT (spark output) connector before you checked the timing?
Old 12-12-2004, 04:53 PM
New Member
Yes, I unplugged the SPOUT then I put at 0 degree the timing. But with Spout connected the problem follow.
Today connected WinALDL and I got a code 42 (Electronic Spark Timing).
I review all vacum hose, changed other MAP and nothing.
Raul
Old 03-15-2005, 02:24 PM
I have the same problem .....i canīt get the timing set properly.....help us
Old 03-15-2005, 05:20 PM
curly5759's Avatar
Code 42 is a problem with the module or wires associated with it. Unless you have access to a repair manual, replacing the module may be the best solution.
Old 03-15-2005, 06:00 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Code 42 will set when the Timing bypass is unhooked.Just clear it out.
Old 03-15-2005, 08:57 PM
New Member
Hola Compatriota
Distante 2000km nos damos la vuelta por USA
I did almost all the probe. Disconnect SPOUT and went changing timing advance in 2, 4, 6 8 degree but the same. I set 0 percent TPS, I reviewed with WinALDL and nothing. Then out Throttle Body and I put other pod with others injectors and.....NO problem, The Idle smoot. I think that the pressure regulator was the problem, diaphragm or spring .
Regards from Chile
You can see us in www.twistedandes.com
