Timing as usual - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2010, 06:47 PM
Timing as usual
I have a 75 GMC 4x4 that I am trying to get tuned in. I have a 350 (not sure what the crank is) but it was a rebuild I bought from my neighbor. He said it was high performance but not a stroker, so whatever that means. I set the initial timing at 16btdc and rpm around 550-600 at idle with the vacuum line plugged off. I revved it up to 3500-4000 and got the timing at 36 total with the advance back on. Then put the idle back to 750-800 and it is good at idle. When I put it in gear it dies unless you keep on the throttle. I think it runs good, it jumps up a little if you get on it which is cool but if you get to a stop sign it will die. Any ideas?
Wes
Old 12-10-2010, 06:58 PM
DoubleVision's Avatar
With vac advance disconnected and plugged, set the base timing to 12 degrees before top dead center. Lock distributor. Reconnect vac advance to a manifold vacuum source (one that pulls vacuum full time, including idle) recheck timing, it should be around 20 - 24 degrees at idle. The idle issue sounds like either it`s got a vacuum leak, idle mixture out of adjustment or trash in the idle circuits. Set the idle screws with a vacuum gauge, simply adjust them to the highest vacuum reading. I would also make sure it`s not flooding at idle, shine a light in the carbs throat at idle and see if you see any fuel coming out of the boosters. You may also want to check the carbs float height.
Old 12-10-2010, 07:08 PM
Thanks, it just got dark on me and I'm frustrated so I'm gonna get some sleep and check it out in the morning. Thanks for the advice, I'm gonna get it done tomorrow. Once, I check the timing at the full time port, do I disconnect it and hook it back to the carb? Also, how do you set the idle screws with a vacuum gauge? Where do you hook it up at?
Old 12-10-2010, 11:22 PM
You connect the vacuum gauge to any vacuum port that`s pulling manifold vacuum which is any port that pulls vacuum at full time, including idle.
As for the vac advance I`m not understanding what you mean. So I`ll start over.
Disconnect the vacuum advance and plug it.
Set the base timing to 12 degrees before top dead center.
Lock the distributor down.
Reconnect vacuum advance to a full time manifold vacuum source (one that pulls vacuum full time including at idle. Can be on the carb or the intake. Either works fine)
Recheck timing at idle, it should be 20 to 24 degrees before top dead center.
If the timing is still at 12 degrees the vac advance cansiter is ruptured and will have to be replaced pronto.
Old 12-11-2010, 07:07 AM
Frisco's Avatar
Glad To Be Here
There is something wrong with the figures you posted.
Using a GM HEI non-computer distributor and setting the initial timing at 16 degrees BTDC with the vacuum advance dis-connected and plugged and the engine RPM below 800 is a good starting point. However, when increasing the engine RPM's to 3500-4000 the built in mechanical advance should have added an additional 20 degrees totaling the 36 degrees you posted without re-connecting the vacuum advance. Adding about 15 degrees for the factory non adjustable vacuum advance should have brought the total up to 51 degrees total mechanical + vacuum timing.
Either your vacuum advance is not working or the mechanical (centrifugal) advance is sticking or being limited internally.
Read DoubleVision's post again and follow it.
Old 12-11-2010, 10:53 AM
well,I did have it hooked to the manifold once and seemed to really smooth things out but a buddy of mine told me it goes on the carb. So, I have a holley 600 and it has a few ports on the passenger side, one is pcv and I thought the one at the top was for the dizzy, there is one more on the bottom that I hooked the dizzy to but it doesn't pull as much as the manifold. So I decided to plug the tranny into it next to the big port for the pcv. So now I just have to start over at the 12degree and try that out. My question about the vacuum for the dizzy, was is it supposed to stay on the manifold all the time or does it ever go to the carb? Thanks by the you guys are cool, I just signed up here yesterday!
Old 12-11-2010, 11:12 AM
A manifold port doesn`t mean as in a port on the intake manifold. Both the carb and the intake have manifold ports. It`s called manifold because it pulls vacuum full time including idle. So yes you can connect it to a carb`s manifold source or a direct source to the intake, either way will work one in the same.
Old 12-11-2010, 12:10 PM
Still Dying
I did exactly what you guys told me to do... I did it at 12 and hooked up the dizzy and got a 20 or so jump, I also did it at 16 and got the same thing around 36 total. No matter what I do it dies when I put it in gear. My idle is around 800-850 in park and it seems like it sounds good but as soon as I go into gear it dies immediatley, just bluh bluh blu then dead. I don't get it...???
Old 12-11-2010, 04:03 PM
so firebird, if it is set up at 24 degrees without the advance hooked up and i get that straight, then plug in the advance and it goes to 34-36 - do I just leave it there if it runs good? I am going out to try it right now. I have checked for leaks and can't find any. Also, if it is at 24 degrees should the rpm still be around a 1000 at idle? Thanks...
Old 12-12-2010, 07:56 AM
Frisco's Avatar
Glad To Be Here
You may have your idle RPM set too low.
Apply the parking brake. Get a buddy to hold the foot brake fully. Block the rear wheels. Start the engine and allow to fully reach 'normal' operating temps. With the wheels blocked and brakes fully applied, put the automatic trans in DRIVE. Set the RPM to around 650-750 when in DRIVE. NOTE: The engine RPM will increase when in PARK. Do NOT increase the RPM while performing this procedure. Check/set the timing while in DRIVE and the RPM below 800. Do not have the vacuum advance hose connected when checking/setting the timing. It should also be plugged. After checking/setting the initial timing, re-connect the vacuum advance hose. If you use a full manifold source for the vacuum (either at the carb base or the intake manifold), the engine RPM will increase. Re-adjust it so that it is just below 800 RPM with the trans in DRIVE.
You will notice that the engine RPM at idle with the trans in PARK will be around 900-1000. It will drop to around 650-750 when in DRIVE.
As others have previously stated, using a more radical cam will necessitate the need for a higher than stock stall speed converter and a slightly higher engine idle RPM than what I have posted above.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
sbc timing question 350pano Engine 8 05-15-2009 10:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 05:47 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
