Timing... vacuum or no vacuum advance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2010, 04:20 PM
454ChevelleMalibu's Avatar
I disconnected the timed port vacuum hose from my Mallory Unilite distributor and plugged the port at the carb. I set my initial timing at ~ 17 degrees. Then I slowly raised the speed of the motor and watched where the timing leveled off. This was at 40 degrees. I verified my idle rpm was at ~ 1000rpm and dropped to about 800rpm when I put it in drive. So far so good. I then reconnected the vacuum to the dizzy and I rechecked the initial timing. I was amazed when I saw my initial timing sitting at 30degrees. I slowly revd the motor again and the timing topped out at 52degrees!!! Thats about the same 22-23degree change in timing. (with and without vacuum advance)
What is going on here? Do I need to fix something? Should I leave the vacuum advance disconnected?
The vacuum port Im hooked up to on the Edlebrock carb is in the front and to the far left. I measured 10psi vacuum at idle. It goes up to over 20 when I slowly rev the motor up. Drops to 0 when I pop the throttle to WOT.
Old 04-17-2010, 04:47 PM
ericnova72's Avatar
More for Less Racer
Hook the vacuum advance up to a non-timed port. Timed port is for emissions purposes only. You want the vacuum advance hooked to a full time source so that it drops off with any movement of the throttle but is high at idle and cruise rpm. Keeps the plugs cleaner and increases gas mileage.
Old 04-18-2010, 07:31 AM
your timing curve looks good to me. how does your engine run?
You can try different initial settings to see what timing your engine likes. Most BBC dyno tunes use 38 to 42 total mechanical timing for max power. Try 38 total mechanical, try 40 total, and try 42 total.
48 to 52 degrees total with the vacuum advance will be good for highway mpg (low load, high vacuum, low rpm)
is your vacuum advance canister adjustable?
Old 04-18-2010, 07:42 AM
Hey guys, thanks for the feedback.
The car seems to run pretty well at 40 degress total. I will experiment with 38 & 42 just to see how it feels in the seat of the pants and throttle response.
My big confusion is should I run with the vacuum advances connected or not? It suprized me when I saw it was at 30 at idle. Is this a bad thing as far as performance goes? I also end up at 52 total with the vacumm connected.
It does launch better with 18 initial and no vacuum advance. What I do notice now is while cruising at say 40mph and I punch it there is a massive stumble and bog. I guess this could be a carb issue and not timing.
Thanks again.
Old 04-18-2010, 07:46 AM
The vacuum canister is a stock unit that came with the Mallory unitlite distributor. Dont know if its adjustable (i'll check). If it is, How would you go about making the adjusments. I mean I know there is an allen key screw up the vacuum snout (if it has it) but what procedure do I follow? Do I adjust it so that at 10psi theres no advance on the timing or just till it feels good?
I really think its the vacuum advance that is the key to the problem here, but what do I know.
Old 04-18-2010, 08:08 AM
yes, 30 at idle seems right. 17 initial plus 13 from the vacuum advance.
yes, could be a carb issue. what carb are you using? could need more accelerator pump or just a bigger squirter.
what heads, cam, compression, gear, ect........
Old 04-18-2010, 09:00 AM
So you're saying I should connect the vaccum advance and let it go even though my final timing is going to end up at 52? Just seems contradictory to everything I've been told. (I'm not trying to be rude, just trying to understand)
I'm just about fed up with that Edlebrock carb and am about ready to by a Holley. Any suggestions?
Equipment:
454 .030 over
Edlebrock 800 cfm carb, Wieand Team G single plane intake with oval ports
Comp Cam Thumper hyd roller cam (11-600-8) with 283 intake and 303 exhaust duration 107 lobe separation, .547 intake and .530 exhaust lift.
Brodix RaceRite oval port heads with 270cc intake runners. Flow: Intake 314cfm @ .500, Exhaust 196cfm @ .500
About 10.25:1 compression, all gaskets and ports are matched up.
3.31 12bolt posi rear end
700R4 Automatic Trans, 2400rpm stall
Headman hearders and 2.5" exhaust system
Old 04-18-2010, 07:23 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
After listening to 454C-10 (and one day I will have to run him down to meet him), and a few others on another site, taking the time to absorb and comprehend what they are saying---and why-------My 454 runs much better.
I am very close to 40* mechanical and a bit over 52 at cruise RPM
Old 04-18-2010, 08:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Equipment:
454 .030 over
You have to remember that the vacuum advance only gives timing when the vacuum is high enough to provide it. Under high load conditions, the vacuum advance is supplying NO added advance.
The adjustment on the vacuum advance is where the advance starts or drops out- not the total amount that is supplied.
The instructions as supplied w/the Crane adjustable vac. can KIT is- http://cranecams.com/pdf/210g2.pdf
Old 04-19-2010, 07:32 AM
yes, the timing from the vacuum advance drops off with no vacuum (wide open throttle).
revving the engine in park is not a load so you get the full timing (mechanical plus vacuum). That is why you are getting 52 degrees when you rev it up the driveway.
your engine is a fairly stout build. I'm sure you will do better with a holley.
an 850 would be a good size for your engine. Use a vacuum secondary carb if you want better mpg or a double pumper for better performance.
I like the classic 3310 750 vacuum secondary carb. very durable, cheap, and they work great. Hard to beat and they only cost about $270. However, it might be a little small for your setup. An 850 vacuum secondary holley goes up to $460! Is 100 cfm worth another $200? That is your call. But on the other hand, you can get by will a little smaller carb since you are using a single plane intake. In any case, a 750 holley or bigger will run better than an edelbrock carb on your engine.
Old 04-19-2010, 07:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This brings up a question I have: Does the stub stack get used anymore? I realize a lot of carbs have gone to different castings w/smoothed airhorns, but like on the "traditional" DP's and carbs like the 3310 that still have the choke air horn, etc.
I have one (stub stack), and when used on a 455 Pontiac w/a 4777 650 DP Holley, my ET and trap speed didn't change. I thought sure it would- IF it actually did what it was supposed to do.
Opinions?
Old 04-19-2010, 08:02 AM
I have also tried those snub stacks at the track without any noticeable improvement. furthermore, it seemed to interfere a little with the carb linkage.
I guess you might see improvement on the dyno or on a carb flow bench, but I'm thinking the overall gains are so small the track improvement would be insignificant.
If cobalt is running a 650dp on his 455 then that might also be a good carb option. again, the single plane intake gets more out of a smaller carb.
Old 04-19-2010, 08:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A bigger carb might've helped my top end- at least that's what everyone always said when I told them what I was running- but because my Pontiac 455 peaked so low (my best ET's were run shifting @ 4900 RPM w/a 3.31:1 diff!), I couldn't justify using anything any bigger.
But that was w/a Performer intake, had I had an RPM intake (they weren't out yet, back then) I would've tried a bigger carb.
But that said, the OP's 454 will have the breathing ability to surpass what the 650 DP can deliver, so I'm w/everybody else AFA using a 750-range carb for good all-around use.
Old 04-19-2010, 08:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I just looked at the engine specs again. Combo's real good, if it wasn't for the Thumper cam and the Team G open plenum intake. That cam has too much exhaust duration w/a too late closing point- just to get a choppy idle. Those heads do not want or need that exhaust timing, IMO.
A different cam would make more power w/as good or better vacuum @ idle. A high rise dual plane would pick up vacuum and have more power under the curve- and possibly on top as well. Something like the RPM.
Old 04-19-2010, 06:57 PM
Hey guys, thanks a ton. I'm taking this all in trust me. I checked a few other posts on the same vacuum timing topic and I think I finally understand the concept. I set my intital (no vacuum) to 18, final to 41, connected the vacuum advance, inital when to ~ 31 and final went to ~ 53. Timing's all set (for now).
Just took the beast out for a cruise and here is where I stand...
1) There is a slight hesitation at intial gentle tip in when leaving a stop light. I have to give it a quick pump to get things going. This is not there when cruising and then gently tapping the gas. Its real jumpy and responsive then. Does this seem like something I can tune out? If so, what to do?
2) From a dead dig or while cruising at speed there is a massive bog when I just flat out stomp on it. Almost to the point of a flat out stall. If I ease my way into WOT (like 60% effort) then it screams like a scaleded dog. I've adjusted the accel pump to the hole closest to the carb (more pump action) to no avail. Should I consider removing the carb and inspecting the accelerator pump stuff? What sort of problems am I looking for. Can I go to a bigger pump just by changing the diaphram?
I know alot of folks are going to scream HOLLEY, but I love to tinker so here we go. I may be screaming HOLLEY as well pretty soon, just hate to give up on parts I already have if I'm close.
Thanks again
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Need some clarification on Timing. Any volunteers? Midwest kid Engine 15 07-22-2009 08:45 AM
220 Temperture, Hot or Just Right? 2000jack Engine 74 06-13-2008 01:25 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
Timing Advance concerns Irnguy Engine 6 07-20-2004 10:16 PM
