Timing with vortec heads
I got my motor built and decided to upgrade dist. to a summit unit with the higher coil/module. Anyways what should my initial timing be set at with this head. I had a guy set it to total timing of 36* and it pings. Now I could back off and drive it and keep doing this til it stops, but realistically is there a number. Seems like the timing is way advanced. The vac. module is almost touching the intake. The guy is a good good mechanic, but he does not know about the vortec heads. He runs dart sportsmans and other stuff.
I know with this head you are supposed to run less timing. Also, should I have the vac advanced hooked up to a vaccum source or not Last edited by Carlos9; 08-11-2009 at 09:17 PM. |
I prefer, use and recommend using full manifold vacuum source for the vacuum advance. |
Yeah, I was told I needed to drive the 87 octane out and replace with 91. We have only 87, 89, and 91 in ca. I've been told that this will solve it. One way to find out is to put some octane booster in it now.. to see what happens. I have to barely drive it or not put a load on it so it doesn't ping. If that does not help, then I'll have to back the timing down a notch.
F-Bird '88 Vac or no vac source to the vac. module. I had it connected without a vac source. We switched it to a vac source off the carb. I was told to put it back the way it was also (may be adding too much vaccum connected) to see what happens. I keep getting told you want a non metered vac source. What's the deal I bought a summit distributor. |
I called summit tech today and they did not know believe it or not. There is an adjustment inside the vaccum module that you are supposed to use a 3/32 allen wrench for. I turned the timing down a bit because it still seemed to high for vortecs (36*). Before I moved it down, I did put 91 octane.. and it helped a lot, but the pinging was not higher in the rpm band. It seemed ok.. but I went ahead and moved it anyway because it still heard pinging.
Now to the distributor.. I'm about to send this thing back to summit. With my old HEI when I floored it, it would shift the truck and get on with business and be at 90 withing seconds. Now when I hit it.. the truck dies. Should I adjust the thing inside the vaccum adcance. I never had a distrubutor like this before.. so kind of puzzled. Also, I am stil confused as to if I'm supposed to have vaccum to the vac module or not. It seemed to run better with the old dist. I also put headers.. and I was thinking it would be louder.. it is quieter. This thing is really breathing too good if that's a possibility. A friend mentioned I needed to fatten it up now with headers. |
You should not have to adjust the vacuum advance cannister at all for your engine combo. More than likely there is nothing wrong with the distributor you got from Summit. The problem is with the timing and /or possibly the carb accelerator pump adjustment. I mention this because you stated that the engine dies when you "hit it". |
Not only does it die, but it does not act like the beast it used to when I nail it. It used to downshift, then get going. Now it never downshifts.. just goes slowly...
til 90mph now. It used to take at least 3 seconds.. now it's taking 8-10 secs to get up to 90 and it's not opening up like it used to. My tranny also started slipping after I added headers. I think the additional 15hp supposedly sent it over the top. Thanks for the information. I will take to my guy today and say do this. Not sure where my timing is at now.. but it was at 36* and i knocked it down about a qtr.
Also, you seem to think the summit dist. are ok. Maybe my problem is with trans.
Is the kickdown cable connected to the carb and is it adjusted correctly? I doubt you gained 15 HP from a header and distributor swap; but even if you did, it should not have "sent your trans over the top". Is the trans fluid level correct? Forgot to mention this but ALL timing info I have posted is for a non-computer controlled distributor and using a carburetor for fuel intake. The timing info does not apply to computer controlled ignition or fuel injected systems. Back to the timing. 36 degrees BTDC for Total Mechanical Timing with no vacuum advance present when the timing is being checked or adjusted is usually too far advanced when running Vortec heads. Drop the timing to 32-34 degrees BTDC and after setting the timing re-connect the vacuum advance hose and use a full manifold vacuum source. Total Mechanical Timing should be "all in" between 2500-3000 RPM. If it isn't, then the centrifugal weight return springs will have to be swapped out to yield the results. Usually on a GM style HEI distributor, using one light and one medium return spring will get you in the ballpark. |
| putting 305 vortec heads on an pre-vortec 350 | thor1022 | Engine | 11 | 01-12-2011 03:17 PM |
| Vortec Heads on a 454 | Torque454 | Engine | 2 | 02-16-2009 09:45 PM |
| What the ***** is wrong with my timing cover/ harmonic balancer!!! | sexypizzaman | Engine | 56 | 10-28-2008 03:49 AM |
| 305 Heads...Vortec or something else? | Ozz1967 | Engine | 0 | 04-13-2006 11:47 AM |
| 5.7 Vortec Heads | Mustangsaly | Engine | 4 | 12-09-2005 07:48 PM |
