Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing woes
Thread: Timing woes
Old 10-04-2012, 11:15 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
the cam is not likely a roundyround cam with 112 lda.do you know what the icl of the cam is? Carb might need a little help with accellerator pump. More info is needed? what rpm are you mashing the throttle and what gear are you driving in at that time?
