Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - timming
Thread: timming
Old 11-09-2012, 04:38 PM
Bronco75 Bronco75 is offline
Cobalt327
I do have the wiring correct for a 351W. And the engine does run good, i am proberly just had my hopes up to much, and exspecting a big block perfromance out of little 302. I do agree with your statement about the gear ratio. I have 350 grears in it, I though I had 4.11's and I did mess up am put 38" tires on it which killed me even more. I have listed all of the copmpnets of my moter below. Tell what you think and what I could do to get more power. when i was builing the moter, I was trying to find a happy medium between low end tourqu and a high reving moter such a dragster you could say. I really built this moter around a 125 hp Noz kit i have and that I did plan on installing. But I never did get try it yet and just might not worry about it.
I do have a question though. I have noticed that my engine loves a lot of timing I think i have the initial timming set at 22 - 25 right now and I couls still go more unitl it bites the starter. you know what i mean. so how do you where to set the timing at?? I think with noz you cant go above 32 degs toal timing right. I tryed several things like locking out the Dist,, changing springs ect. but nothing make a real diffance.
Oh and I have the world product Jr's and I did not port or gasket match. Soi know that one week area I have. I read that once you port these heads it really wakes them up. what i really want is some alum. heads I hear trick flow is right up there with best perfomance.
engin specs:
302 BORDED 60 OVER WITH 1975 STOCK ENGINE BLOCK
CAM SHAFT BUILT BY CAM MOTIONS IN BATON ROUGE LA - GRIND# S2361-2401-12 - CORE 149002 (351 FIRING ORDER)
LOBE SIZE - (2) : 2
CAM SHAFT DATA = 4 CRNK DEG
DURATION @ .05 IN
INTAKE - ROCKER RATIO = 1.6. LASH IN 23-24-25-0
EXHAUST- ROCKER RATIO = .06 LASH IN 23-24-25-0
INSTALL CAM : CYL 1#
LOBE SEPERATION = 112 CAM DEG
VALVE OVERLAP = 13.5 CRANK DEG
INTAKE
VALVE OPEN = 9.9 BTDC
CENTER LINE --- 108 ATDC
VALVE CLOSE = 46.2 ABDC
DURATION ----- 236.1 CRANK DEG
LOBE LIFT = .32268 IN
VALVE LIFT ---- .51628 IN
LOBE AREA = 27.04 IN *DEG
EXHAUST
VALVE OPEN = 50 BTDC
CENTER LINE --- 116 BTDC
VALVE CLOSE = 3.6 ATDC
DURATION ----- 239.6 CRANK DEG
LOBE LIFT = .33677 IN
VALVE LIFT ---- .53883 IN
LOBE AREA = 27.08 IN *DEG
VALVE LASH SET TO 24
HEADS
WORLD PRODUCT / WINDSOR JR. LITE CYLINDER HEADS
VAVLE INT = 1.94 IN
VALVE EXH. = 1.60 IN
COMBUSTION CHAMBER VOLUME = 58 CC
INTAKE RUNNER = 180 CC RUNNER VOLUME (PORT DIMENTION 2.00 X 1.12)
EXHAUST RUNNER = 64 CC RUNER VOLUME (PORT DIMENTION 1.300 X 1.22)
HEAD BOLTS 7/16 THREAD BOLT
HEAD GASKETS - FEL PRO 1250 OR FEL PRO 1011-2
INTAKE GASKET - FEL PRO 1415 OR EQUIVALENT
SPARK PLUGS - USE 5/8 REACH - ACCEL 278
VALVE SPRING SEAT PRESSURE - 190 TO 200 IT HINK THIS CORRECT
HEAD BOLT TORQUE (MOTER 302) UPPER ROW 80FT/LBS; LOWER ROW 70 FT LBS
ROCKER ARM STUDS 55 FT/LBS ( I USED A FIXED SETTING / VALVE LASH)
WHEN I BROKE THE CAM SHAFT IN I REMOVED THE CENTER VALVE SPRINGS
ROCKER ARMS
JEGS ROLLER ROCKERS 1.6 RATIO
PUSH RODS USE
FORGED (
FIRING ORDER
PRE - 1982 (302)
1-5-4-2-6-3-7-8
WHAT I DID (351 FIRING ORDER) 1-3-7-2-6-5-4-8 I THIN K I USED THIS ONE
FIRE WALL
4 8
3 7
2 6
1 5
Front bumper
PISTIONS USED
KEITH BLACK HYPEREUTCTIC PERFORMANCE PISTIONS
RINGS
SPEED PRO
GROUND THE RING GAP TO .0025 TO .0035
TIMEING CHAIN
DOUBLE ROLER
SET AT FACTORY SETTING (TIMMING MARK)
PUSH RODS
USED A ADJUSTABLE CHECKING PUSH RODS 5/16 DIA. 6.125 TO 7.500 LENTH
USED EAGLE FORGED RODS
CONNECTION RODS
EAGLE FORGED
INTAKE
WELAND 7515 SINGLE PLANE
HEADERS
HOOKER HEADERS
IGNITION
DIST. MDS - WITH MDS SPARK BOX
oh yea one more thing when I put that big cam in I had to use a adjustable push rod to get a measurment for my new push rods, so when i order the push rod I gave them the leanght that I measured, they did not send me the excact leanth I ordered but it was real close. but i did not degree the cam. so that sould make a differance as well right?
I really want to thank you for your help, I have learned so much sence this project began I will send you a pic if can figure out how lol I think you will love it..
