Timming - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2002, 12:43 PM
Post Timming
I have 1994 Mits. Mirage with a 1.5 engine. About two week ago the timming belt. I know how to put the timming belt on, but I don't know how to set the timming back. I had someone to set the time for me, but after the timming was set the car wouldn't start. Could you please help me, me need instruction how to set the timming.
Old 11-08-2002, 04:17 PM
F-1Rodder's Avatar
Post
Get hold of a repair manual for the car and follow the directions. I have never worked on a Mitsubishi Mirage, but there are usually marks on the cam and crank that need to be aligned, this is usually pretty easy to do.
Are you sure you don't have it correctly aligned, but have gotten the ignition timing wrong in the process? Remember that the crank turns over twice for every engine rpm. If you installed the cam with the crank 180 degrees out of phase, this would cause your spark to be 180 degrees off.
Old 11-08-2002, 07:21 PM
BOBCRMAN@aol.com's Avatar
Post
angie the reason the car won't start after correctly timimg it is the valves are probably bent. most of these small motors are "interfearance" motors, this means if the timing goes off for any reason the piston will hit and bend the valves.
