Timming Chain & Gear set question : - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 03:08 PM
Ratoflic's Avatar
Big cubic inches small Chevy!
Hi,
One of my friend have a 585 CI dragster engine. We need to change the Timming Chain & Gear Set. We are not able to find the brand....and a timming chain part # to be able to buy a new one.
On the Camshaft Spocket, we find this part number : 3501-AX, Does somebody can help us to find the complete part number to put a new one.
The Engine block is a Merlin II.
Thanks, Stephane
I have another Question:
Need to figure out what camshaft we have in this engine ;
There is the number and identification on the camshaft....I was looking on internet and find absolutly nothing :
CR 13-52-05
SSRE 4200.
Does somebody can direct me in the right way...because we need to put new lifter and Spring.
On the lifter vertical bar...we see part # 502.
Thanks to help me in our process.
Thanks..stephane
Chevy man forever!
Old 02-01-2011, 04:28 PM
Try these guys
Scott Shafiroff Racing Engines
http://www.shafiroff.com/
I would consider using a belt drive.
Old 02-01-2011, 05:59 PM
spinn's Avatar
The summitracing double roller chain is never let me down, $20 . After the initial stretch, fine.
Old 02-01-2011, 06:10 PM
ericnova72's Avatar
More for Less Racer
Like Imsport has posted - SSRE is Scott Shafiroff Racing Engines. I'd contact them for everything you need to know. Go right to the source so there are no discrepancies.
I don't think I'd use a $20 timing set in a $15,000 racing engine, and especially not with the spring pressures of a roller cam.
Simple Timing Gear/Chain Question leejoy Engine 1 02-23-2008 09:09 AM
trick to getting timming chain off? 71javelin Engine 5 12-30-2006 05:42 PM
Gear vs. Chain Lolly20 Engine 24 07-06-2005 11:51 AM
QUICK! Crank n timming chain question? HemmiGremmie Engine 2 10-20-2004 07:59 PM
timming chain rookie Engine 1 12-28-2002 07:25 PM
