When you set the timing, the vacuum advance has to be disconnected and plugged. Then set it to 9 BTDC (or whatever). If the vac. adv. WAS disconnected, the mechanical advance springs could be so light that they're allowing timing to come in at idle speeds or the mechanical advance mechanism is sticking/dirty/rusty. |
Gapped the points to .016
The advance weights are not stuck. I even lubed the swivel points on the weights with a non-oil lube. (RemOil) I will check the advance springs. I disconnected the vacc hose during timming and it changed nothing. I sucked and blew on the hose end and the timming did not change. I think the dist. diaphram is bad. The vacc hose goes from the dist. vacc can, to a 6 connection water heated operated vacc valve at the front of the intake next to the water neck. There was no vacc suction on this valve when we checked it. The engine was cold. Is this connection correct? Should'nt it be to a constant vacc sourse? It seems that the vacc to the dist. would only work when this valve opens when the motor is warm. Garett |
For now, just run a full-time vac. source from one of the carb vac. ports to the distributor vac. advance can. Just be sure that you use a full time port, not one for the EGR or a ported source. And you will need a vac. adv. can that works. Points-type dist. use a different can than an HEI. Which brings us to the distributor in general. Unless this is a resto-deal, look for a non feedback (most pre-'81, some post-'81 trucks) distributor to replace that old attention-demanding points distributor. |
COLBALT327
If I have to replace the vacc can, do I would have to pull the dist? Or can it be done left in place without alot of hassel? If it would be easier to do it pulled. Wouldn't I be better to install a new HEI dist? If yes, which one? There are so many available. Can I run a HEI for now with the stock Pontiac coil? Or should I get a Accel or Mallory? I want to do this right. Not cut corners. We have a SBC 350 4 bolt main that we are going to build and put in it. Will a Pontiac 350 dist fit a SBC? THANK YOU VERY MUCH for you knowledge and time to answer my questions. Here is what me and my son are doing this year. Not quite done. Got the motor and tranny left to do. Garett Last edited by gman536; 12-28-2009 at 05:44 PM. |
You want a distributor that has the vacuum advance and mechanical advance built into it. These are '80-older for use w/o a computer. Some trucks also used the older style HEI, up well into the 80's. The HEI cannot use the same wire that is used to power the points dist.- it has resistance built into it. HERE is an article that talks about replacing the wire, etc. Quote:
Good luck. |
You can install petronix ignition in place of the points, And you can do it with distributer in better if out but not bad while it's still in. It takes about 10 to 20 minutes depending on you. I have ran them in several cars with no problems. http://www.google.com/products?hl=en...ed=0CCIQrQQwAg . Hope this helps it's real easy to install. Just two wires a few washers goes in right where the old points where at buy the kit and get the blaster coil to match you will be ready to go in no time.
Cole |
But anyway, what is required for powering it- does it require a new 12V non resistor power wire? Or can it run off of the points-type resistor wire that is already in his F-Bird? |
So I can leave the stock dist in place and just replace the guts??
Why buy 2 dist when I'm going to replace the Pont 350 with a SBC 350. Glad I decided to come on line and ask you guys I was a mechanic 30 years ago. Worked for a school dist. It is amazing how much basic knowledge I've lost since then. Sucks getting old!!! This project with my 17 yo son has beeen a blast Hope I can remember most of it when I start building the motor. If not, You guys are close by Thanks again. Garett |
Cole |
| 96 3.8L GM engine dies seconds after startup | 49Austin | Electrical | 6 | 11-27-2008 12:40 PM |
| Taurus SHO engine issue... just one thing after another. | ViperMonster800 | Engine | 9 | 04-21-2006 05:48 PM |
| New Engine Built & Dyno'd | babe_n_indy | Engine | 69 | 09-09-2004 07:26 PM |
| Engine dies after start up.... | FenderGitars | Engine | 3 | 08-27-2004 08:44 PM |
| engine timming | nrichardson | Engine | 3 | 11-25-2002 03:29 PM |
